Old 02-15-2015, 04:29 PM   #1
scoobopdan
Drives: 2008 Yaris
noise coming from inside door
There's a noise coming from the inside of the driver side door (manual windows) that rattles when bass hits or I go over a weird bump, etc. It only happens if the window is all the way up; if I lower it even just a tiny bit then the rattle won't happen. So my two questions are: has anyone had anything similar to this before? 2) Can anyone give me some info (or a link) on how to disassemble the door?
scoobopdan is offline   Reply With Quote
Passender Door Permanently closed chri DIY / Maintenance / Service 8 07-27-2015 12:05 PM
Left turn noise - coming from right side tenchsama DIY / Maintenance / Service 0 07-18-2013 11:37 AM
HB Common Door courtesy switch signal? Yaross DIY / Maintenance / Service 2 01-25-2011 11:57 PM
Will missing door vapor barrier contribute to condensation when it rains inside? YarisSedan General Yaris / Vitz Discussion 4 02-11-2010 09:18 AM
3 Door Stick coming to Hendersonville NC Search General Yaris / Vitz Discussion 5 04-20-2006 10:11 PM
