Old 02-16-2015, 11:34 AM   #1
desidude
Drives: Toyota Yaris 2007
Quick 2007 Yaris oil change question
Hi friends,
Wishing you a very happy new year. My a partner owns a 2007 Toyota Yaris hatchback in Houston, TX.
It has about 95,000 miles on it. It is due for an oil change, and I am wondering what brand of oil (non synthetic) you recommend? And also what brand of filter?
Also, the oil change shop offers bulk oil and bottled oil, the bottled oil is more expensive. Any thoughts?
I am a newbie to car servicing and trying to learn, and yes I am reading the forum!!
Thanks,
desidude
desidude is offline   Reply With Quote
Old 02-16-2015, 11:37 AM   #2
Kar98
Drives: 2011 Scion tC
I wobble back and forth between Valvoline and Mobile1, whichever quick oil change station is more convenient that day, and I stick to what it says on the filler cap, 5W30, synthetic. At least that's what I tell them to put in. I'd hope that's what they do put in.
Old 02-16-2015, 11:41 AM   #3
bronsin
bronsin's Avatar
Any oil that meets the requirements in the OM will work. I believe its designated something like SM or SN. You can find that on the label.
Personally I advise against having something like Jiffy Lube change the oil. Plenty of horror stories of their inexperienced workers doing damage...stripping drain plugs, under or overfilling crankcases, putting auto trans oil in etc etc etc.
Old 02-16-2015, 11:54 AM   #4
desidude
Thanks friends. I was actually thinking of going to Walmart and getting my own oil. The Walmart near my house is nicer than most.
My regular mechanic is a drive away, thus I was thinking that instead of making the Trek to him, Walmart should be able to handle it...
Am I taking too much of a risk?
Old 02-16-2015, 12:07 PM   #5
You are over thinking it.
In the US have the Walmart service centers changed over to Mr. Lube like they have here in Canada?
Old 02-16-2015, 01:42 PM   #6
Not all Walmart in Canada have Mr.Lube. There are about 45 or something stores in Canada that's were converted into Mr.Lube
On a side note, many ppl in the states have to travel a fair bit of distance to get to a Walmart, while I access 4 different Walmarts within 30 mins drive radius.
Old 02-16-2015, 02:50 PM   #7
sheekeebut
Minimalist
Drives: 07 silver sedan
Yaris manual says go anything ILSAC multi-grade.. Don't know what that means, but GF-4 is the minimum I find around here. GF-5 on the Mobil1 full synthetic I get when on sale, but completely unnecessary. It's just a bad, wasteful habit. Like smoking..
If you're in it for economy and reliability, I think you're supposed to go with anything conventional. It'll be the frequency of oil changes that will matter more, they (won't say who) say.
If you don't trust the oil change/tire guys, you're one of thousands. I don't trust them, because I used to be one. I've seen all sorts of crap at the generic oil/lube/tire places. I'd rather do it myself, so if I break something, I'll have a better idea of what got broken, I'll learn to fix it, and I've got no one to blame but myself for any automotive f'ups.
sheekeebut is offline   Reply With Quote
Old 02-16-2015, 02:56 PM   #8
sheekeebut
Minimalist
As for choice of filter, I'd go with that second-cheapest one you find for your make/model.
For mine, I go with the mobil1 filter to match my oil, coincidentally on sale at the same time, and I get suckered another $5 or so, thinking I've opted for the quality product and therefore peace of mind.
Old 02-16-2015, 05:45 PM   #9
Ben_
Drives: 2010 Yaris Hatch
I have been using Mobil 1 synthetic and Mobil 1 filters change every 7.5k. 10w20 as per the TSB
Will be using k&n filters from MI and 10w20 brand-x synthetic for my next change. I tear my oil filters apart with tin snips after changing and have seen 100% clean filters so far. Fingers crossed that it will continue happening
Ben_ is offline   Reply With Quote
Old 02-17-2015, 08:35 AM   #10
bronsin
bronsin's Avatar
My 1974 VW Beetle had no oil filter (and only 2.5 quarts of oil) and the bearings in the engine were still within spec at 250,000k miles. True it needed a valve job and pistons and cylinders every 100k or so. But that's probably because it was an air cooled engine.
So I doubt very much you will find junk in your filters! (there isn't any in a well maintained engine)
Old 02-17-2015, 12:16 PM   #11
10w20?! That's way too thick at cold for North American driving...
Old 02-17-2015, 02:41 PM   #12
sheekeebut
Minimalist
Like, pancake syrup.
Old 02-17-2015, 05:14 PM   #13
Ben_
Pardon my french I meant 5w-20. I should really check these things before I open my fat mouth
Old 02-17-2015, 05:25 PM   #14
Btw, I though TSB said 0w20. Not 5w20. :)
I run 0w30
Old 02-17-2015, 05:27 PM   #15
bronsin
bronsin's Avatar
Just a thought here...
Would you really use 0-20 oil in 90+ degree temperatures?
Sounds too thin to me...
Old 02-17-2015, 06:20 PM   #16
sheekeebut
Minimalist
Why not 5W30 as the manual suggests?
Old 02-17-2015, 11:19 PM   #17
Ben_
5w30 is a good choice. 5w20 will be thinner and give better mpgs (in theory) and Toyota gave a service bulliten suggesting its use so either is acceptable
Old 02-18-2015, 12:22 AM   #18
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Does anyone have a copy of said TSB?
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
oil change question chickmagnet8301 DIY / Maintenance / Service 8 01-21-2007 02:13 PM
