Old 02-17-2015, 07:32 AM   #1
CD88
Drives: toyota yaris
2005 Yaris HELP....
Hi, I'm new to this so I appoligise if I have posted in wrong section.
I have 2005 Yaris 1.3 petrol. And when battery was flat the terminals where crossed and have blew the ECU. So I've went and got new ECU and key with transponder ring. Changed all the fuses that where blew. But car still won't start. Fuel pump is running but there is no spark. Have tested power to coils and injectors and I'm not getting any???
Is this an immobiliser issue or is there something I'm missing?
When I changed ECU I changed keys and responder ring? Anything I'm missing?
Any help really appreciated.
Thanks
CD88 is offline   Reply With Quote
Old 02-17-2015, 08:24 AM   #2
The new ECU has to be programmed for the new key.
Old 02-17-2015, 08:42 AM   #3
CD88
ECU and key kit is out off another yaris?
Old 02-17-2015, 05:53 PM   #4
So, the ECU, key and the transponder key amplifier (the ring around the ignition switch) are all from the same Yaris (and it was known to be working when it was disassembled)?
Old 02-17-2015, 05:58 PM   #5
Also, do you have normal keys or the entry and start system? If you have the entry and start system, the body ECU is involved as well.
If you do not, the things I would check are:
1. 15A AM2 fuse under the bonnet
2. Check the coil packs to make sure they haven't been damaged
3. Check for +12 volts on the brown wire of the #1 coil pack with the ignition switch on, to make sure the IG2 relay is working.
Toyota yaris hatchback headlight fits on Vitz 2005? urguardian Cosmetic Modifications (Exterior/Interior) 2 09-11-2014 04:46 PM
Toyota Hybrid R Shows Its Yaris Roots MadMax General Yaris / Vitz Discussion 0 10-10-2013 06:14 PM
I have problem with the electro ventilator yaris sedan 2005 ramy DIY / Maintenance / Service 3 08-26-2013 08:08 PM
2005 Yaris noise in engine area dwoodpub General Yaris / Vitz Discussion 5 12-27-2010 06:41 PM
