Old 02-17-2015, 12:56 PM   #1
trowa
Drives: Toyota Yaris Sedan 2008
loud noise when i put first or reverse, transmission problem.
I have a strange noise when put first, reverse or lower gear.
all started after changing the clutch (ac competition clutch) and flywheel.
at first sounded just being cold engine.
At the moment the engine sounds so cold or hot.
change bearings clutch but still the same.
it may be that the box has a problem with a bearing not know.
apologies for the English, I speak Spanish natively.
from already thank you very much.
trowa is offline   Reply With Quote
Old 02-19-2015, 06:40 PM   #2
canadian deacon
Drives: 2014 yaris 5dr
It's hard to know what the problem is without hearing the noise. Is there a vibration too? If so, is the vibration worse as the car accelerates?
Does the noise occur during shifting or when in gear? Can you describe the noise?
canadian deacon is offline   Reply With Quote
Old 02-27-2015, 09:22 PM   #3
trowa
the noise happens when I 'm stopped and put first or reverse .
It 's like an old door opening .
then acelerate and change to second the noise disappears.
yes theare a vibration but disappears when rev high
i have change my flywheel and clutch to ceramic disk.
Old 03-01-2015, 03:26 PM   #4
Echo86
Drives: 2003 Toyota Echo
Check the exhaust system. I recently had the pipe separate and would vibrate at low rpm, at idle and reverse. I got the same old door opening sound.
Echo86 is offline   Reply With Quote
noise, noise while moving., transmission
Funny noise when in Reverse sirshunted DIY / Maintenance / Service 21 07-07-2007 02:17 PM
Line Noise Problem Arkhangel In Car Entertainment + Electronics (audio / video / alarm) 2 04-09-2007 03:41 PM
2007 LB Auto-Trans NOISE in Reverse Pavel Olavich General Yaris / Vitz Discussion 4 03-22-2007 07:42 PM
Anyone Else having this problem???? MeggiemobileSFLA DIY / Maintenance / Service 3 03-01-2007 05:37 PM
Loud scratching noise dngz General Yaris / Vitz Discussion 3 09-11-2006 10:56 PM
