Old 02-17-2015, 11:23 PM   #1
Nate6390
Drives: 2008 Toyota yaris sedan
2008 sedan belt
I have a 2008 sedan and when I start it whether hot or cold it tends to squeal. I've also noticed that it squeals when the rear defroster is on or the headlights o the fan. When I'm driving and am on the gas this tends not to happen. But if I let off the gas while in motion or the car is just sitting and running it will start squealing and the headlights will dim. However if I give it some gas the squealing will stop. The car has a new belt on it just for reference. Any help is greatly appreciated! Thank you!
Nate6390 is offline   Reply With Quote
Old 02-18-2015, 06:02 AM   #2
You prob just need to adjust it. But if it slipped so much that it glazed, then you need a new belt (again).
Stay away from dayco belts...
Old 02-18-2015, 10:13 AM   #3
Nate6390
Sorry I'm not much of a mechanic what would need adjusted? And what kind of belt would you recommend?
Old 02-18-2015, 10:25 AM   #4
The drive belt may need to be adjusted. Your machanics would be able to do that.
Old 02-18-2015, 11:21 AM   #5
Nate6390
Thank you I'll be looking into this!
2008 Yaris Sedan Shop/Service Manual willardjwilliams DIY / Maintenance / Service 4 12-09-2016 10:57 AM
2010 4 Door Sedan exterior fits 2008 Sedan? kev2077849 General Yaris / Vitz Discussion 4 02-07-2013 11:21 PM
Squeaking Sound underneath 2008 Toyota Yaris Sedan Automatic SDYarisGuy DIY / Maintenance / Service 3 02-27-2011 05:36 AM
focos delanteros y traceros para sedan 2008 jchavez81 Central and South America 2 09-11-2009 09:12 PM
