Old 02-21-2015, 01:19 PM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
2jz Supra Powered 93 ExtraCab Pickup for sale
So over at one of my other forums there is a gent that is looking to sell his 1993 Yota Pickup with a 2jz swap! They are talking around 7k for it which having a pretty well done 2jz install into a pickup so that all sensors, lights, etc work perfectly I would think could be a hell of a bargain especially since it is a platform that could be built off from if you wanted. If timing were better I would snap this up as a hauler for Tiamat!
2jz-gte VVTI swap in 93 Toyota Pick Up (Kilwy)
Here is a link to his thread on TuneMyToyota.com:
93 Supra Highlux
Finished:
- Power mirrors
- Power door locks
- Power windows
- Tacoma (4runner) Bumper
- 19" TRD wheels
- 2" drop
- Alum Radiator
- Idle stablizer
- 4x4 front fenders
- 4runner marker lights
- Custom door panels
- New cam and crank seals
- Ditch the cozzey windows
- New Idler arm
- HD steering dampener (4x4)
- Alignment
(didn't plan to do)
- Alignment again
- Replace passenger glass
- Valve cover gaskets
- VVTI cam o-ring (leaking like a beoch)
- Fix the mistery water leak in the cab
- Weld new mounts onto radiator (didn't clear engine)
- make lowering mounts for shock
- cut front and rear bump stops in half
- replace drivers door handle
Old 02-27-2015, 02:15 PM   #2
Jedz123
Two Wheeled Fiend
Drives: 08 Yaris 2D Lftback 5-speed
that is just tooo cool!
2008 Suzuki B-King
2001 Yamaha FZ1 (2005 motor swap)
1998 Suzuki Bandit 1200S
1983 Suzuki GR650
2008 Toyota Yaris 2DR HB (The Cage)
Jedz123 is offline   Reply With Quote
