Old 02-27-2015, 11:03 PM   #1
07stlYaris
If Its Not Blown It Sucks
07stlYaris's Avatar
Drives: 07 Yaris LB Meteorite
Blitz for parts or repair.
I have the Blitz that Tolmach (look up posts) had from an xb. The clutch bearing spun on the snout so it will need either a fixed pulley or a sleeve where the clutch bearing sits. The supercharger spins fine and boosted even with the aforementioned bearing problem. I'm selling it as used for parts so theres no issue regarding the fact that its needing some work. I'll take $500 shipped anywhere in the lower 48. Let me state this again, it NEEDS a bit of work to make it fully functional again. Do not buy unless you have access to a machine shop. I'll include the blitz fmc and bracketry so all you need to do is fix the snout and you should be good to go.
07stlYaris is offline   Reply With Quote
Old 02-28-2015, 07:29 AM   #2
any pictures of the issue?
Old 02-28-2015, 11:20 AM   #3
07stlYaris
07stlYaris's Avatar
Sold. No pics but if you've ever seen the snout without the clutch, it has 2 snapring grooves (inner for the stator and outer for the rotor). The area on the top of the snout where the rotor bearing sits (in between the grooves) is now a few thousandths smaller making the bearing wobbly on the shaft.
Old 02-28-2015, 11:45 AM   #4
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
wow that was quick. the entire install hardware even with the required fix, such a cheap price
Check out my Build thread:
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 262 11-23-2022 05:49 AM
Looking fo blitz or blitz parts unikyaris Willing to Buy by private party 2 01-16-2014 08:57 AM
Blitz throttle controller 808_Yaris Performance Modifications 43 10-22-2009 04:36 AM
BLITZ HAS CLOSED????? ROCKLAND TOYOTA General Yaris / Vitz Discussion 12 08-13-2009 05:35 AM
GI: OFFICIAL BLITZ YARIS laszlo Cars for Sale by private party 11 11-25-2008 05:05 AM
