Old 03-02-2015, 02:09 PM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Twin Charging - anyone have the stones?
Found this article and shed some light on how it works at least to me so I thought I would share:
Twin Charging
Depending on how things go and if I could figure out space issues I could possibly consider this in a few years.....maybe......pipe dream? lol
Old 03-02-2015, 03:41 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Yes. It's on the to-do list with the 2ZR-FE upgrade. I've got the blower, might as well get the snail.
Old 03-02-2015, 03:42 PM   #3
fnkngrv
fnkngrv's Avatar
you could get away with a relatively small snail too like the Zage or the one that I had previously.
Old 03-02-2015, 03:57 PM   #4
CrankyOldMan
That's kind of where I was headed with that idea. I think the Zage would be a good starting point for proof of concept, if only because it's bolt-on and relatively inexpensive.
Old 03-02-2015, 04:01 PM   #5
fnkngrv
fnkngrv's Avatar
according to the article you can run both chargers 10/10 and get the effect of 30! that is nuts. it would require a well built engine regardless of whether it would be a 1nz or 2zr. Also you would probably want to try to get lower than even the 9:1 ratio in the engine for it to stay together with any longevity.
Old 03-02-2015, 04:27 PM   #6
CrankyOldMan
You also need twice the intercooling--sending hot, compressed air into a compressor isn't what you want to do. Plan on having one after each, possibly air-water to conserve space. I've looked into that as well, and it seems pretty straight forward.
Old 03-02-2015, 07:03 PM   #7
fnkngrv
fnkngrv's Avatar
the IC can be pretty small for the SC. You could even stack them.
Old 03-03-2015, 04:59 PM   #8
kou
Drives: 08 lb
My zage snail and most of the kit will be up for sale in the next few months as I am upgrading.
Old 03-04-2015, 06:16 PM   #9
CrankyOldMan
Saliva intensifies.
charging issues help please shockedmustang DIY / Maintenance / Service 9 02-24-2014 01:28 PM
Charging voltage for stock battery Vinceb DIY / Maintenance / Service 3 02-12-2011 12:10 AM
Twin Charging whooppee777 Forced Induction Forum 68 04-28-2009 07:02 PM
