Old 03-09-2015, 09:41 AM   #1
rbeldua
rbeldua's Avatar
Drives: Toyota Yaris 2008
Engine won't start
Hi to all,
I have a toyota 2008 yaris, battery is 3 mos old and after 3 to 4 engine start and drives around with A/C on and lights on, it losses power and it won't crank up the engine. I know the alternator is working as I disconnect one battery pole connection and it still runs. It seems as if its not charging via alternator.
can anyone help me out here, I am kinda lost with this one.
rbeldua is offline   Reply With Quote
Old 03-09-2015, 12:49 PM   #2
nortonfb
Drives: 2007
Check the output of the alternator with a meter.
If you don't have a meter most big box stores will check it for no charge.
Norton
nortonfb is offline   Reply With Quote
Old 03-09-2015, 06:02 PM   #3
Check the large fuses on the positive battery terminal the one between the alternator and battery may be popped.
Old 03-11-2015, 03:41 AM   #4
rbeldua
rbeldua's Avatar
Norton
as suggested, we took it to a battery dealer to have it check for the alternator and it charges.
also we did that while in the battery dealer, the fuses are intact and the meter shows continuity. Is the charging system has any connection to the computer module?
Old 03-11-2015, 06:14 AM   #5
The battery dealer may have checked the fuses in the fuse box, but not the ones on the positive terminal. Those are built into the plastic assembly, so you can't easily check for continuity.
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 09:08 AM
Boost Gets U Laid eh? Count me In yaris2010RS Forced Induction Forum 128 02-02-2013 04:57 PM
slight clutch kickback after engine start?? marcus DIY / Maintenance / Service 0 09-17-2010 11:05 AM
The last gas question Tonavi DIY / Maintenance / Service 56 04-27-2009 08:40 PM
