Old 03-18-2015, 11:26 AM   #1
dinky123!
Drives: 2008 Toyota Yaris
Front Right Headlight and Rear Left Taillight Bulbs
My Front Right Headlight and Rear Left Taillight Bulbs are out. Just wondering if I should try to do it myself or if I should take it to Hill Tire...I have a 2008 Hatchback 2 Door Yaris.
dinky123! is offline   Reply With Quote
Old 03-18-2015, 02:29 PM   #2
sex
sex's Avatar
Drives: 09 5DR
Find an hour and some tools to DIY. I suggest changing both front bulbs at the same time otherwise you may find yourself under the hood for the other side.
Old 03-18-2015, 04:19 PM   #3
If you have small hands, and understand how the bulb is secured in the housing, you may be able replace the fronts without dismantling the car. There is a bit of room on the passenger side to work your hand in, but the driver side is considerably tighter. Lots of discussion on here about the blood loss in attempting to replace bulbs without pulling the bumper.
The easiest method is to partially pull off the bumper cover and remove the headlight assembly. Once the assembly has been removed, bulb replacement is very easy.
http://www.yarisworld.com/forums/showthread.php?t=11227
WTB - projector headlight and rear spoiler ezhacker1 Willing to Buy by private party 0 04-02-2011 07:35 PM
FS: 09LB Bumper, Taillight, HeadLight, Side Mirror, parts, etc.. AlainMikli Items for Sale by private party 27 05-17-2010 10:04 PM
Lowering springs, turbo manifold, front driver headlight Moses Willing to Buy by private party 4 01-24-2010 03:00 AM
