Old 03-20-2015, 06:02 PM   #1
Rocko855
Drives: Yaris 1.33 2010
2010 Yaris 1.33 engine rattling
Hi every one I have a 2010 Yaris 1.3. 1nr fe engine it starts up fine but is shaking and rattling on idling when driven its low in power and struggles to get any power changed few things but so far by couple of mechanics not given a definite answer could it be a burnt valves Pistons car has 90k with full Toyota history any advice would be much appreciated Thanx.
Rocko855 is offline   Reply With Quote
Old 03-21-2015, 07:15 AM   #2
bronsin
bronsin's Avatar
No CEL?
Old 03-21-2015, 07:42 AM   #3
Do a compression test
Old 03-21-2015, 04:12 PM   #4
Rocko855
Had a compression test done but conclusive
Old 04-07-2015, 03:13 PM   #5
Mikastef
Perhaps you need to make the mechanic clean the throttle or reset the ecu... Mine previously shook when idle and had to reset the ecu
Mikastef is offline   Reply With Quote
Old 04-08-2015, 03:58 AM   #6
lambros
lambros's Avatar
Drives: TOYOTA YARIS S 2009
This engine idle works between 520rpm and 540rpm because has the ECO start/stop system for faster fire down and fire up....no problem
lambros is offline   Reply With Quote
Old 04-09-2015, 08:44 PM   #7
pesho
Drives: Yaris 2011
Can you write what you change and what you try ? Any error codes? It is a automatic or manual? Share some info :D
Best!
pesho is offline   Reply With Quote
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Engine goodies for the Yaris botchilah Performance Modifications 8 01-28-2009 09:52 PM
