Old 03-24-2015, 10:26 PM   #1
azn_driver
Drives: Toyota Vitz
Aftermarket Mirror install. Now driver side door wont lock???
Odd problem that IMO seems to not relate to eachother...
Installed the new power mirror, without a hitch..power windows, and mirror function still works.
except for the driver side door lock will not lock, tried to reset the body ECU by disconnecting the negative of the battery for 10 minutes.
But still no go with locking.
Any ideas where to look?
Thanks for everyone on your help.
azn_driver is offline   Reply With Quote
Old 03-25-2015, 05:52 AM   #2
Can you manually lock it? If you can, I would check the door lock motor.
Old 03-25-2015, 06:26 AM   #3
The door lock and power mirror both route through the door harness, so I would make sure that the connector did not get accidentally pulled from the lock motor and also make sure that the lock cable did not get pinched when the door card was put back on.
Driver side foglight trim gwasabi Willing to Buy by private party 3 03-03-2009 03:11 AM
Replacing driver side mirror? supernes550 Cosmetic Modifications (Exterior/Interior) 4 01-26-2009 11:11 AM
Problem with driver's side lock maryinredding General Yaris / Vitz Discussion 3 01-05-2009 09:32 PM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 05:55 PM
The Driver Side River Nutzoids General Yaris / Vitz Discussion 7 12-14-2006 01:11 AM
