#1 |
![]() Drives: 2008 Toyota Yaris Join Date: Mar 2015
Black piece of plastic on underside of body
As if burned out bulbs aren't enough, now a piece of plastic on the bottom of the car is scraping against the road when I drive the car. I have it "tucked" back, but this will not hold for very long...any ideas?
![]() ![]() ![]() ![]() Join Date: Feb 2010
well did you get under the car and look ? without any information I would guess you have a screw loose, missing or a broken panel. seeing that you are driving a seven year old car, that would be my guess. it really should not be difficult to figure out if you actually take a look.
#3 |
black piece of plastic
I think this piece of plastic is part of the undercarriage, but I don't know if it is essential. I don't know if I should try to take it off. Is this just a plastic cover for the bottom or is it more important?
#4 |
engine under cover
Ok, so the piece is called the "engine under cover". By this description, I would say it is needed/essential. How can I bolt it back on?
#5 |
It really isn't essential, but if you want to reattach it as is, drilling some extra holes in it and attaching it with cable ties is the easiest way.
#6 |
Thank you for a straight answer...I will worry about my front and read bulbs first...
#7 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
It just healpds protect your engine from road crap. Given the amount of salt on the road where I live, I would consider it pretty important. In your case living in SC, maybe not so much. Like Scott said you can use cable ties or get a few plastic plugs from the dealership, if the iriginal hole are still in good shape then just install the plugs through the holes.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| White Yaris Wide Body !!!!! | clickis | Photo-Video-Media Gallery | 49 | 01-27-2012 02:31 PM |
| I need a body kit | LA Yaris | California | 1 | 11-06-2009 01:26 AM |
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 08:52 PM |
| Toyota Throttle Body Spacer: the Best Fuel-Saving Device | davidmills | Performance Modifications | 1 | 07-01-2007 11:38 PM |
