Old 04-12-2015, 10:29 PM   #1
GrayYaris
Drives: Gray
Rad Support bent to sh*t
I have noticed the bottom part of my radiator support has been seriously bent for a few years but I now have a leaking radiator which has forced me to look a little closer under the car. I noticed that the left side of the rad the support is crushed also! Previously I assumed that the bottom piece bending was just from hitting frozen slush in the winter but after a second look that metal is pretty thick. Does anyone else have a bent radiator support due to frozen flush in the winter?
Here is a picture of the bent piece on the left (left side of the car) of the radiator.
Here is the rad leaking and support under it totally bent.
btw Any recommendations on a decent radiator that won't leave me broke?
GrayYaris is offline   Reply With Quote
Old 03-01-2016, 03:51 AM   #2
JudgeM
JudgeM's Avatar
Drives: 2005 Toyota Vitz RS
I don't know if this is possible in the area you live, but there are places that can repair radiators.
JudgeM is offline   Reply With Quote
Old 03-01-2016, 09:49 AM   #3
Just get a used one an flush it before use.
Old 03-01-2016, 10:12 AM   #4
^this. Shouldn't be very expensive.
Old 03-01-2016, 10:44 AM   #5
you might want to replace that rad support too if you can unbolt it.
Old 03-01-2016, 04:11 PM   #6
jcboy
Drives: Sedan 07
might have been in an accident before? used one from a junkyard that passed a pressure test of would ideally be the least expensive.
Old 03-01-2016, 08:17 PM   #7
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
Actually, I just ordered those two pieces for my car. I got side support and the lower rad support for $48 shipped. Mine wasn't bent quite that bad, though. I did hit a snow pile when I bent mine. I didn't even realize I bent anything until I started my engine swap.
The rad support comes apart super easy. One nice thing about this setup.
brushforhire is offline   Reply With Quote
Front seat modification. Increase thigh support. PetersRedYaris DIY / Maintenance / Service 36 08-22-2018 01:37 PM
Bent brake drums after installing new rims angrygenerator Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 08-01-2013 12:09 PM
Idea For Japan Relief Support Kaotic Lazagna Off-topic / Other Cars / Everything else Discussions 9 04-06-2011 09:30 AM
new Ontario Race Track - NEEDS YOUR SUPPORT!! TrackAddict Canada 13 12-15-2009 07:30 AM
Rostra seat heater and lumbar support sesmith In Car Entertainment + Electronics (audio / video / alarm) 1 01-03-2009 08:51 AM
