Old 04-13-2015, 08:11 AM   #1
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Ac delete
I want to remove my AC from my Yaris HB. Does anyone know what the new belt size will be ?
Thanks
Old 04-13-2015, 09:03 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Do you have any mods? I know CTScott recently posted that a Blitz supercharger with A/C delete is 55". You can also use the old "string" method--get some non-stretching string (nylon surveying line) from the hardware store and wrap it around the pulleys. If you measure it yourself, please post the length.
Old 04-13-2015, 10:33 AM   #3
55" is way big, even with A/C. Without A/C the belt is very short.
thebarber, who owned a Yaris without factory A/C, claimed 360mm was belt length.
Old 04-13-2015, 11:04 AM   #4
CrankyOldMan
I just assume everyone here has a supercharger. =)
Old 04-13-2015, 12:00 PM   #5
A lot of us wish we did.
Old 04-13-2015, 12:05 PM   #6
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Thanks for the replies. I was trying to stay away from string method. I was hoping someone already knew the measurements. Ill start with 360mm. Looks like ill be removing AC in the parts store parking lot.
Old 04-13-2015, 12:23 PM   #7
If you are running an underdrive pulley (can't recall if you are), then you will need 355mm.
There is room to run the shorter belt without needing to get the compressor out of there.
Old 04-13-2015, 02:13 PM   #8
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Yea, you dont' need to remove the A/C compressor to run the A/C deleted belt.
-Derrick-
Old 04-13-2015, 02:39 PM   #9
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Thanks everyone ! I have used the AC maybe 3 times since i bought the yaris in 2006. I just want that 10 lbs gone.
Old 04-13-2015, 11:48 PM   #10
ivanstepul
Drives: 08 hatchback
Does it increase power with naturally aspirated engine. Is there a difference that can be felt.
ivanstepul is offline   Reply With Quote
Old 04-14-2015, 12:40 AM   #11
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
If Scott chimes in that would help a lot. He is who told me which belt to buy when I deleted mine.
Old 04-14-2015, 12:42 AM   #12
fnkngrv
fnkngrv's Avatar
Scott and I agree I believe that it doesn't make much of a difference when you aren't using it. There isn't enough drag really. I only removed mine because od how my ext wastegate piping got in the way. If there was any way I could I would put it back in personally. I find the car stuffy without it during warm months.
Nevermind Need To Delete this Post LEXX DIY / Maintenance / Service 2 10-01-2011 02:40 AM
Is a cat delete midpipe stinky and loud? Shinare Performance Modifications 5 10-30-2010 06:48 PM
Rear emblem delete shadowking Cosmetic Modifications (Exterior/Interior) 40 04-19-2010 09:38 AM
Rear Seat Delete, help? JustlikeSuki Cosmetic Modifications (Exterior/Interior) 22 09-18-2009 03:54 AM
