Old 04-14-2015, 03:02 PM   #1
th3fitz
Drives: 2008 Toyota Yaris 5D Hatchback
60/40 for bench seat Swap
I believe I've tracked down some 60/40 seats for my Yaris. How hard is it to swap out the seats?
th3fitz is offline   Reply With Quote
Old 04-14-2015, 03:31 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Depending on the age of your car, the bolts can be almost impossible to remove. They're reverse Torx head bolts (E-type?) and can strip fairly easily. I don't know about a DIY, but there should be some info in these forums.
Old 04-14-2015, 03:41 PM   #3
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
There were some issues as noted here.
If you want it done right, CTScott did an extensive DIY here.
Old 04-14-2015, 03:44 PM   #4
The 60/40, as you'll see in the links above, requires more bolts than the solid bench. The holes in the floor pan for the extra bolts do not exist. For some, there is a receiver nut in place, requiring a hole to be drilled to it. There is another one where no hole or nut exists.
I've put a 60/40 in mine, but have yet to drill out for the additional bolts. As far as welding is concerned, I don't see why it is necessary to weld the extra nut in. I would think a nut and washer drawn tight would suffice.
Old 04-14-2015, 06:20 PM   #5
I posted a DIY when I did one on my red Yaris. You could use nuts if you have a helper and will have them again if you ever need to remove it. I welded mine.
Old 04-17-2015, 08:59 AM   #6
th3fitz
Do the years of the seats matter much for how much work is involved? Seems like i have the crappy end of the stick for installation lol
Old 04-17-2015, 10:03 AM   #7
No, all Gen2 seats are constructed the same. I have an '06 and put in seats, front and rear, from a '10.
Elaborate.
DIY: 60/40 Split Seat Install (some welding required) CTScott DIY / Maintenance / Service 13 03-05-2017 04:12 PM
60/40 to Bench Seat Swap Issue CTScott Cosmetic Modifications (Exterior/Interior) 24 11-26-2012 02:45 PM
Feeler: Swap my hatchback 60/40 rear seat for your solid two piece bench rear + cash auxmike Items for Sale by private party 12 11-11-2012 07:52 PM
60/40 split rear seat swap question jayeh Cosmetic Modifications (Exterior/Interior) 12 10-28-2012 03:07 AM
