Old 04-15-2015, 08:45 AM   #1
hatchbackkid82
Drives: .
Flashing TPMS
I have a 2010 Yaris sedan that has just developed this issue. Checked the tire pressure, thinking one of the tires was low. They were all fine, nothing, the TPMS light is still flashing. I know when a tire is low, the light will stay lit, but I've never seen it flash. Can anyone shed some light on this? The battery died a few days ago, would the battery dying have anything to do with this?
Old 04-15-2015, 10:13 AM   #2
Damn nanny gadgets!
I'm guessing either a faulty TPMS sensor, or battery in one of the sensors is running low.
Old 04-15-2015, 11:28 AM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Dealership or Toyota certified shop will have to put their techstream laptop on it and find out which one isn't responding. Either replace it which is a couple hundred dollars including labor or, leave it broken and do the DIY TPMS Bypass which is found here:
http://www.yarisworld.com/forums/showthread.php?t=11058
-Derrick-
Old 04-15-2015, 12:23 PM   #4
nortonfb
Drives: 2007
If you have a Discount Tire near you try them.
They reflashed my wife's car at no charge.
nortonfb is offline   Reply With Quote
Old 04-16-2015, 09:32 AM   #5
hatchbackkid82
Drives: .
So drove home yesterday and the light never flashed at all, it was solid the whole way home. Drive it this morning to work and it's flashing. Screw I'm just gonna bypass it, my 2007 LB never had it and I was fine. Thanks guys
Old 04-16-2015, 11:26 AM   #6
ilikerice
ilikerice's Avatar
agreed. I hate the TPMS so much. I tried to keep mine because I didn't want to have that damn light on, but eventually after swapping out 10 sets of tires, someone ended up cracking one and of course the person who found it claims it was already like that. I just threw those in the trash. I check my pressures once a month anyways.
-Derrick-
Old 04-16-2015, 01:06 PM   #7
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
There's a diy on bypassing the tpms light around here somewhere. Basic soldering skills is all you need.
Old 04-16-2015, 01:50 PM   #8
Read post#3
Old 04-16-2015, 02:19 PM   #9
CrankyOldMan
I work for the Bureau of Redundancy Bureau.
Old 04-16-2015, 07:35 PM   #10
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Why not just have it scanned a new sensor is only like 40$ at Toyota and 10 min to install plus 5 min to program
Old 04-16-2015, 08:30 PM   #11
You can read it yourself with just a paperclip or piece of wire.
Turn the ignition to ON and jump the TC and CG pins of the diagnostic connector and watch the flashing pattern of the warning light:
11-14: Transmitter 1-4 operation stop
21-24: No signal from transmitter 1-4
41-44: Transmitter 1-4 error
65-68: Abnormal temperature 1-4
71: Transmitter not registered
73: Vehicle speed sensor signal malfunction
76: Receiver error
81-84: Transmitter 1-4 ID not received
94: Engine speed signal error
Old 04-17-2015, 09:49 AM   #12
ilikerice
ilikerice's Avatar
Dammit Scott, I hate you but I love you at the same time. Making me do things myself but also saving me crap loads of money
-Derrick-
TPMS questions NEexpat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 08-02-2013 05:18 PM
DIY - - -TPMS work around rningonfumes DIY / Maintenance / Service 6 03-03-2011 08:11 PM
TPMS light on after swapping 1 tire from different car nvidiaxtc DIY / Maintenance / Service 5 02-02-2011 09:45 PM
tpms compatibility? bwong2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-11-2009 09:33 AM
TPMS Gauges - do they exist? Sodium Duck DIY / Maintenance / Service 24 03-01-2009 12:18 AM
