Old 04-22-2015, 11:38 PM   #1
dstephens1962
Drives: 08 yaris
Fuel Guage help
I saw a while back a post regarding stuck fuel Guage and cleaning the contacts on the sender. Is there a step by step anywhere? And how well does it work? What's the best way to test after?
Thx
2008 yaris 120k
dstephens1962 is offline   Reply With Quote
Old 04-22-2015, 11:50 PM   #2
If you are going to go through the hassle of pulling the fuel sender (remove rear seat, open floor hatch, remove gas tank top), you should probably just plan to replace it.
You can try using a good fuel system cleanser first, as that may help.
Old 04-22-2015, 11:56 PM   #3
dstephens1962
Drives: 08 yaris
OK can I just replace the sender and where do I get that.
Old 04-23-2015, 07:12 AM   #4
You typically have to purchase an entire fuel sender unit to get one, as Toyota doesn't sell them separately. If you are interested I actually have just the fuel level sender on hand from a fuel sender assembly that I used for calibrating fuel pressure regulators. I could do $25 shipped on it.
Old 04-23-2015, 05:55 PM   #5
dstephens1962
Drives: 08 yaris
I'm going to pull it this weekend to try and clean it, the car did sit for 6 months. If that doesn't do it I pm you.
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
Do any Yaris owners use premium gas ? DanMC Third Gen Yaris General Discussion 38 11-06-2013 11:36 AM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 04:34 AM
fuel guage issues bonusjonas DIY / Maintenance / Service 4 12-07-2011 09:52 AM
NEED ENGINE CHECK LIGHT CODE LIST Attitude Forced Induction Forum 12 04-11-2011 07:38 PM
