Old 04-29-2015, 07:41 PM   #1
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
Alternate LED Hyperflashing Fix (2nd Gen. only)
Originally covered in this post, and in this post, here is another way to fix your rapid-flashing signal lights after changing 1 or more of them with LED bulbs.
It`s the easiest and fastest method, and should be used whenever possible.
1. First off, get yourself a special turn signal flasher made specifically for LED bulbs.
I got mine from here: http://www.diodedynamics.com/store/l...signal-flasher
2. Once you receive it, cut off the 2 tabs circled in the image below.
Here's a picture of how it should look like:
3. Next step, get in your car and remove the little storage cup in the lower left side of the steering wheel.
Then, locate and remove the OEM flasher relay. (circled blue in the picture below)
4. Put in the special LED relay, and you`re done. Put your little storage cup back and enjoy.
Old 10-10-2015, 09:07 PM   #2
SirDigby
Drives: 2007 yaris 3 door
this is awesome.
thanks!
Old 10-11-2015, 10:02 AM   #3
I have tried that before. Finally just gone back to halogen bulbs for flashers. The only reason is because the first flash takes about 1-2s before it starts flashing normally.
Sent from my A0001 using Tapatalk
Old 10-11-2015, 01:50 PM   #4
SirDigby
ah. that can be an issue....
Old 10-12-2015, 06:49 AM   #5
invader166
Pumpman
Really donno. It's true that your signal light will stay on for about 1/2 second before it'll start flashing, but that would be the only "issue" with using this unit.
I've also yet to hear any comments from law enforcement officials about it either.
Old 08-08-2021, 08:35 PM   #6
KermitAUS
Drives: Yaris 2009
Will this work on a 2009 Toyota Yaris 3 door?
KermitAUS is offline   Reply With Quote
DIY - Converting a 2nd gen Yaris to the best part of a 3rd gen (Steering wheel audio) CTScott DIY / Maintenance / Service 12 01-22-2022 03:09 AM
2nd vs 3rd gen ride quality + durability chocolab Third Gen Yaris General Discussion 23 11-17-2014 07:30 PM
2nd Gen owner's impressions: 3 days with a 3rd Gen (2013 5-door LE 18k miles) nookandcrannycar General Yaris / Vitz Discussion 7 02-22-2014 08:16 PM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
Yari gets a sway bar and a rim change (again) D&D Photo-Video-Media Gallery 8 09-16-2013 01:10 AM
