Old 05-01-2015, 12:01 AM   #1
Caramanos2000
Drives: 2012 Yaris 5dr Hatch
15mm Spacer Question
Will a 15mm spacer on the rear require me to shorten the stock lug nuts in order not to hit the back of the wheel?
Caramanos2000 is offline   Reply With Quote
Old 05-05-2015, 02:46 PM   #2
WorkTL
WorkTL's Avatar
Drives: 2013 Yaris LE
Do you mean the spacers that come with their own studs and bolts to attach to the existing factory studs?
WorkTL is offline   Reply With Quote
Old 05-05-2015, 02:49 PM   #3
WorkTL
WorkTL's Avatar
If so, most wheels have groves in the rear for the factory studs, if no grove you will have to trim facorty studs, order shorter studs, order longer studs and stand alone 15mm spacer, or dremel groves into the rear of the wheel (not recommended).
I ran 20mm spacers (H&R drm) and the factory studs stuck out past the 20mm spacer.
Old 05-05-2015, 02:52 PM   #4
Thebigwicks
Drives: 2008 lowered yaris on 17's
If you are talking about bolt on spacers, then the only way you could get away with not hitting the back of the wheel is if you had a wheel with the indentions on the rear of the wheel. if not our studs stick out about an inch so the smallest bolt on spacer that you could use without modification would have to be a 25mm spacer.
Thebigwicks is offline   Reply With Quote
Old 05-05-2015, 02:52 PM   #5
Following his other threads, it would appear he is still referring to this;
Originally Posted by Caramanos2000 View Post
Would these be appropriate?
Old 05-05-2015, 02:55 PM   #6
Thebigwicks
Basically the back of your wheel would have to look like this.
License Plate question awebb005 Cosmetic Modifications (Exterior/Interior) 5 11-11-2014 08:28 AM
For Sale: Project KICS 15mm spacer w/ hub center enviri Items for Sale by private party 1 04-14-2014 07:42 AM
Best Rear Spacer SeriousBlack Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 08-22-2011 02:44 AM
Wheel/hub spacer, PLS help evo165 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 08-18-2009 02:21 AM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
