Old 05-05-2015, 05:41 PM   #1
coyotevitz
Drives: 2006 Vitz 2sz-fe
Speedo hit 80kph with the ignition on
Hi! I have a 06 Vitz 2S-ZFE analog speedometer
The speedometer hit 80kph with the ignition on without engine start.
Also when I am driving I stop the car and the speedometer hit the 80hph and I hear something hard in the transmission feels like somebody hit me in the back.
When I remove the feet from the brake pedals the speed going normal to cero again.
Thanks JB
coyotevitz is offline   Reply With Quote
Old 05-05-2015, 07:02 PM   #2
Does it have an automatic transmission? If so, the instrument cluster feeds the speed to the ECM, and if either the speed sensor is feeding it bad info, or if something is wrong with the speedo where it is feeding the bad info on its own, the ECM will not shift the transmission correctly.
Old 05-05-2015, 09:58 PM   #3
coyotevitz
Hi! Yes is automatic! Do the speedo read the transmission sensor or abs sensors?
Old 05-06-2015, 01:04 AM   #4
For the Japanese market Vitz, the speed input to the cluster does come from the ABS sensors (via CAN bus message from the ABS ECU) instead of from the transmission sensor.
Old 05-06-2015, 10:31 AM   #5
coyotevitz
Thanks for all your answers!
Old 05-18-2015, 11:17 AM   #6
coyotevitz
Hi! Problem solve, it was the front right abs sensor, the reading was 274kph in this side!
Thanks for the help!
Door trigger for Rear Right RR door missing enve1160 In Car Entertainment + Electronics (audio / video / alarm) 12 12-29-2010 10:14 PM
Got hit at work today, lady drove off. Prohibit General Yaris / Vitz Discussion 41 11-04-2009 11:38 PM
