Old 05-20-2015, 11:04 PM   #1
antone
Drives: 2007 Yaris
Arrow Rear brake drum shoe change
Hi all,
I'm hoping I can manage doing the rear brakes after replacing the front pads/rotors.
I tried searching but not much details on the work involved. I've gone over the repair manual. Wondering if you can share your experiences.
I haven't actually taken the drum off to inspect but I figure since it has never been changed (2007, with 110,000kms) and already doing the fronts. I won't have to worry about it for another 100k.
Other than getting new drums and shoes, should I spend the extra to get the spring kits or do most people re-use existing?
Appreciate it!
Thanks
Antone
antone is offline   Reply With Quote
Old 05-20-2015, 11:14 PM   #2
sickpuppy1
Drives: 2010 Yaris Sedan
Unless you've got a warped drum there is no reason to buy a new one. That being said, I would check the rear shoes first, as they wear very slowly and I'd be surprised if they need to be replaced.
Old 05-21-2015, 05:07 AM   #3
Don't worry about replacing the drum or springs unless there is an issue with either.
Take a picture before you start or use the other side to remember how the springs go back. You likely won't need new shoes yet b ut you should go in there and spray/clean them out and re tension the brakes tighter. I know it has an auto adjust system but I never find those work well to keep the brake as tight as I prefer.
Old 05-21-2015, 08:36 AM   #4
antone
Drives: 2007 Yaris
Thanks for the replies, probably right they may be fine as i dont drive/ brake hard. i was thinking of putting new for peace of mind
Old 05-21-2015, 08:44 AM   #5
Even with hard braking, the rears do so little of the stopping that it's extremely hard to ever have an issue where new drums are needed.
I take a small air grinder and shave down the lip which causes them to sometimes be a pain to remove. Other than that I leave them.
Old 05-21-2015, 09:10 AM   #6
245,000 kms on mine and I'm just now at the point where I do need to address replacing shoes.
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
Drum brake/parking brake devinlamothe DIY / Maintenance / Service 0 04-14-2012 08:30 PM
rear brake drum parts yv1650c DIY / Maintenance / Service 0 09-26-2010 11:08 PM
Rear brake proportioning valve??? PetersRedYaris DIY / Maintenance / Service 16 03-25-2007 11:10 PM
