Old 06-18-2015, 06:53 PM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Feeler: Turbo Manifold and Downpipe with Cat
Would there be interest in my log style turbo manifold and downpipe? Manifold can easily be mated to the Zage turbo, 62mm turbos, or other small turbos like the disco potato. It is designed to be used with an external wastegate and dumps into the Downpipe. T25 Flange. The DP has a V-band inlet on it that is 3" and would come with a gutted cat and wrapped with premium heat wrap. The DP reduces to 2.5" after the cat using T-409 stainless which can withstand heat very well. Lemme know! I can post pics if there is interest.
DISCLAIMER: IF YOU HAVE AC THEN YOU WILL EITHER LOSE IT OR YOU WILL NEED TO MODIFY THE DUMPTUBE FROM THE WASTEGATE BECAUSE THE DUMP PIPE LINES UP PERFECTLY TO BE IN THE WAY OF THE AC LINES GOING INTO THE FIREWALL. THE OTHER OPTION I WAS TOLD WAS YOU COULD HAVE THE AC LINES MODIFIED TO BE 90 DEGREE INLET RATHER THAN STRAIGHT IN!
FS: Partial HKS turbo kit for Yaris 33OH Items for Sale by private party 18 07-23-2011 03:37 PM
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 10:24 AM
small update on turbo project... joey1320 Forced Induction Forum 26 08-03-2007 04:29 AM
