Old 06-19-2015, 11:07 AM   #1
NEexpat
Drives: 2009, auto, 4dr LB
How are those hardware store chip keys anyway?
Answer: Fine, in fact at $44.00 and change they are better than fine!
Local Ace hardware is doing a $25.00 off chip key Fathers Day promotion. So I went in and got one. Took all of about 5 min, and total was under $45.
If you have been putting this off and need a second or even a third for other drivers in your house etc., do it. Even without the special it would have been about $ 70.00.
This is the key I will always use and keep the original Toyota keys in a safe place,............................................ ....... just in case.
Cheers.
NEexpat is offline   Reply With Quote
Old 06-20-2015, 09:08 PM   #2
attrapereves
Drives: 2010 Yaris 2dr 5spd
Could you post a picture of what the key looks like? I may be interested in getting a spare.
attrapereves is offline   Reply With Quote
Old 06-21-2015, 07:12 AM   #3
NEexpat
attrapereves,
Here is the link to the website with the image.
Here
That is the exact key I received.
Old 06-22-2015, 10:12 PM   #4
KingForADay
KingForADay's Avatar
Drives: 2013 5 dr. Liftback Yaris LE
I'm a bit noobish at this, but I was under the impression Toyota had a proprietary code that only they could reset as far as extra keys and the engine immobilizer goes. I'd be happy about this though just in case I need a third.
Did you notice if they sold the same type of keys but with lock/unlock/panic buttons?
KingForADay is offline   Reply With Quote
Old 06-23-2015, 08:09 AM   #5
NEexpat
King,
I believe if you have lost the original "master" keys to the car then you are correct with having to go to the dealership etc.
I have the original keys so I think this hardware store program simply replicates the "code" if that is correct, in the master to the new chip key.
Of course I maybe completely off base here, but that is my understanding of it.
It is just the key no buttons etc. My key less is aftermarket, that I installed myself with the assistance of this forum. So I have the chip key and a separate fob.
I have looked into trying to get a combo key/fob for an aftermarket system. No luck.
cheers.
Old 06-30-2016, 08:34 PM   #6
NEexpat
*Bumping this.
ACE Hardware around here is running their $25.00 off chip key special for 4th of July weekend again.
If you only have one chip key, get another, you won't regret it.
cheers.
Old 06-30-2016, 08:58 PM   #7
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
so i have to ask how do they code the key to ur car?
Old 06-30-2016, 09:07 PM   #8
kimona
kimona's Avatar
Drives: 2014 White VITZ
My local Ace Hardware makes flat chip keys... but only up to 2013 models. I found a local mobile shop that made a key (in my driveway) for my 2014 for $60 including programming... and it took just 10 minutes!
Chip Key Sale FYI NEexpat Off-topic / Other Cars / Everything else Discussions 0 08-28-2013 02:30 PM
Chip key made at ACE Hardware NEexpat General Yaris / Vitz Discussion 3 12-03-2011 02:34 PM
