Old 06-23-2015, 07:35 PM   #1
Droid
Drives: Yaris 2009
Question Clicking noise!
Hello-
I am hearing a faint clicking sound, sounds like a bicycle freewheel, when my Yaris is moving in drive or reverse- clicks increase evenly with speed, no clicks while idling. I have looked under the vehicle and haven't detected any debris attached to the axle or frame. has any one experienced this before? Any thoughts? Thanks for any input -
Droid is offline   Reply With Quote
Old 06-23-2015, 07:55 PM   #2
Stone in disc brake dust shield maybe.
Old 06-23-2015, 08:13 PM   #3
andulong
andulong's Avatar
Drives: 2008 Hatch Red
If it were mine, I would jack up one corner of the car at a time and give the wheel a spin to see if I can reproduce the sound. If not it might be in the drive line somewhere. good luck.
andulong is offline   Reply With Quote
Old 06-23-2015, 09:22 PM   #4
fourbangingfun
fourbangingfun's Avatar
If it's anything like this
http://youtu.be/79KPXKrsZao
Then it might be a small stone trapped inside the brake rotor. Do what he ^ said and figure out what wheel is it coming from.
fourbangingfun is offline   Reply With Quote
Old 06-23-2015, 09:59 PM   #5
Droid
Drives: Yaris 2009
thanks!
thanks for the responses- I will do as advised and update the forum- i think this might be the culprit fingers crossed. Thanks again!
Old 06-24-2015, 07:04 AM   #6
Stone in brakes or tire like the above posters stated. It could also be your C/V axle which is doubtful due to it being an '09 but check to see if the boot is ripped at all on the axles
Old 06-24-2015, 12:23 PM   #7
shepd
Drives: 2007 Yaris 5 door RS
Double check all your lug nuts are secure.
Don't ask how I know that this can cause that sound. :(
shepd is offline   Reply With Quote
Old 06-24-2015, 02:42 PM   #8
nookandcrannycar
^^^^^ This was my first thought...having had this happen on other vehicles.
Weird clicking noise from front right wheel - low speed Blanketnam DIY / Maintenance / Service 2 05-19-2015 03:58 PM
'06 Yaris wont start, clicking noise phillidg DIY / Maintenance / Service 1 10-22-2013 08:13 PM
Clicking Noise while Turning Bella Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 06-12-2010 01:13 AM
Clicking noise when jerking steering wheel side to side/hit bumps left side eii DIY / Maintenance / Service 8 03-22-2010 06:46 PM
Clicking noise in center console? devinlamothe General Yaris / Vitz Discussion 8 09-16-2006 11:03 AM
