Old 07-03-2015, 10:13 AM   #1
Stardom
Drives: 2007 Toyota Yaris
2007 yaris
my 2007 yaris will not start the problem is not the starter however the starter will click but not turn HELP !!!
Stardom is offline   Reply With Quote
Old 07-03-2015, 11:09 AM   #2
valchrist90731
Drives: 2007 toyota yaris sedan
Your battery is dead and it is probably due to the alternator or the voltage regulator within that. How old is your battery?
valchrist90731 is offline   Reply With Quote
Old 07-03-2015, 11:15 AM   #3
valchrist90731
Use a multi meter and check your volts.
If you have a manual transmission you can push start it.
But take money and tools with you to auto store.
I highly suggest you get a ride from a friend or family member to the store with your battery.
If you don't have a multi meter.
should read 12.5 or 12.6 volts for in good standing.
Old 07-03-2015, 11:56 AM   #4
alanwagen
battery
Does it have the original battery? You are overdue. I try to change mine before they strand me. One thing I always look for is to see if the sides are swelling a little. That means some sort of BS is going on in the old battery.
The reason it just clicks is that there is not enough juice to turn over your starter motor. Very typical dead battery symptom. Tell us when you get it resolved.
Napa carries a battery that fits perfect. Autozone and Walmart, no.
Actually the dealer has good prices for some weird reason. Around 100 bucks
2007 and up Yaris Sedan S McDizzle New YARIS Purchase Forum 3 12-03-2009 01:42 PM
