View Poll Results: Should I just turbo the 1nz or swap the 2zr, document, and then turbo it?
Turbo the 1nzfe 5 41.67%
Swap in the 2zrfe 7 58.33%
Voters: 12. You may not vote on this poll
Old 07-09-2015, 05:22 AM   #1
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
Turboing my car
Is the Zage turbo kit still available? I can't seem to find anywhere to purchase it?
Or does anyone have any other suggestions for a good kit? I saw a company called Turbo Specialties, but I read alot of sketchy stuff about them.
Or at least a decent manifold and down pipe that I can source out the rest of the kit myself?
I don't have anywhere near me that really does custom work, or at least any I would trust when I comes to stuff like that.
Last edited by brushforhire; 07-16-2015 at 12:53 PM. Reason: Got my answer and now wanted to start something else.
brushforhire is offline   Reply With Quote
Old 07-09-2015, 09:28 PM   #2
brushforhire
This is about the only turbo kit I can find right now. I did some more digging and it seems like it is a decent company, and it comes complete with engine management. Turbo Specialties.
Old 07-16-2015, 12:55 PM   #3
brushforhire
So I received what I needed to know about the Zage kit, and should hopefully have a kit in my hands shortly. I would like to use this thread as my build thread. It will a slow and methodical thread explaining what I am doing along the way and why. I hope to be able to help others who want to do this too. I have been throughly inspired by others on this forum and totally excited to make this journey too.
I hope to eventually be in the 250+ hp range.
Old 07-16-2015, 02:14 PM   #4
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
good luck. These are always interesting to watch.
-Derrick-
Old 07-16-2015, 02:39 PM   #5
Freestylin
Freestylin's Avatar
Drives: 09 Blizzard Pearl RS LB
Thats good to hear! Are you going to be changing out the stock internals of the motor for the 250hp build? Usually, the stock internals can handle about 10psi at most before you run into reliability issues. Running 10psi will probably get you into the 170-180hp range.
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” ― Ayrton Senna
Freestylin is offline   Reply With Quote
Old 07-16-2015, 03:31 PM   #6
brushforhire
I do plan on a build after I get the initial install of the turbo kit done. I work at a dealership, so I can get some decent prices on used engines. I plan on doing a build on an engine stand on a second engine.
I want this project done, but not gonna rush anything.
Old 07-17-2015, 12:19 PM   #7
WorkTL
WorkTL's Avatar
Drives: 2013 Yaris LE
Can you please PM me where you got the Zage? I'm in the market myself.
WorkTL is offline   Reply With Quote
Old 07-17-2015, 12:24 PM   #8
Just post up parts sources here. No reason why where stuff can be purchased should be kept secret.
Old 07-17-2015, 12:39 PM   #9
brushforhire
All secret! Sorry. J/K!
I messaged Cali Yaris. He said he can still get them.
I plan on posting how I install everything, along with were I got the parts along the way.
Old 07-17-2015, 09:00 PM   #10
kou
Drives: 08 lb
You can order the kit directly from Zage.
Old 07-17-2015, 09:01 PM   #11
brushforhire
I tried contacting Zage before I found out Cali could them for me, and I never received any response back. It always bother's me when I tell someone I want to give them my money and they make me work to give it to them.
Old 07-19-2015, 01:09 AM   #12
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I ran 9psi with my custom setup and was pushing around 190 to the wheels. Going 10 on stock internals WILL cause accelerated engine wear requiring a rebuild much sooner. 170 to the wheels in this car is very fun. Really isn't any reason to get to 250 unless you just have cash to burn as it will require a bottom end build at the least. You will also lose 15 or so mpg at that power number. It will require a full fuel system upgrade. Lastly I am pretty sure the Zage will not get you to 250 anyway. Best of success with your build and ask questions if you need to. Btw I have a head with valves I am selling for 250 for someone to do a port n polish on. Pretty good price as it only has 35k miles on it.
Sent from my SCH-I545 using Tapatalk
Old 07-20-2015, 04:23 PM   #13
brushforhire
ugh, I'm so torn. I just called my local yard, and they can hook me up with an XD 1.8 and ECM for $750. I am thinking I want to go and swap that in and then turbo that instead.
Opinions?
Old 07-20-2015, 07:26 PM   #14
Do the 1.8!
Not enough documented engine swaps around here.
Old 07-20-2015, 08:11 PM   #15
brushforhire
Do the 1.8!
That is one of the reasons, I was thinking about doing that also. To do a "how-to" type of deal. Or more accurately "how I fumbled through an engine swap, so anyone can do it" thread.
Since I can't make up my mind, I decided to start a poll and see what everyone else thinks!
Old 07-20-2015, 09:11 PM   #16
fnkngrv
fnkngrv's Avatar
Do the swap and boost that. If I hadn't done had the engine I have now I would have done the swap then boost it to 8-10psi. That should get you to 220 easy I would think. Might even be able to do it without a fuel system upgrade either.
Old 07-21-2015, 03:29 AM   #17
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
I might be one of the few, if not the only one who thinks you should keep the original engine. This is only because you're kinda going into unknown territory. Yes, that new engine might bolt-up and work just fine, but keep it mind that the vehicle was originally designed for a different engine. You don't know how it will affect your chassis, suspenssion, etc...(or maybe someone has documented this, if so feel free to jump in)
Of course cars are overbuilt to have a certain factor of safety, but with a new engine, who knows? You and your passenger's safety might not be as high in the event of a collision. (not that I ever want you to have one of course)
Old 07-21-2015, 07:53 AM   #18
brushforhire
That is a good thought, but I thought in Europe and japan they were available from the factory with the 1.8. So, I would assume, that they would be virtually the same and the chassis would be okay.
XB HKS turbo kit, on an echo taKuto Forced Induction Forum 28 01-14-2013 09:39 PM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
zage turbo kit..! just need some help joseyaris Forced Induction Forum 12 10-29-2009 08:35 PM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 12:30 PM
