Old 07-11-2015, 10:05 AM   #1
crazylegs
Drives: 2007 Yaris
1NZ-FXE forged rods??
Was just looking at wikipedia at different Toyota engines and noticed that the 1NZ-FXE has forged steel rods and also noticed it also runs a high compression ratio. Like the Prius. I know this engines output is much lower then our stock set-up but it got me wondering if anyone looked into mating the rods with our stock engines. Can it even be done as a straight swap, and how much more power could this allow you to push theoretically. I'm sure the stock rods are only reliable to 200whp.
Like I said just stumbled on the info and I though I'd ask.
crazylegs is offline   Reply With Quote
Old 07-11-2015, 01:09 PM   #2
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Rods are the same between the fe and fxe.
2014 BSpec Divisional Champion
Old 07-11-2015, 01:37 PM   #3
crazylegs
Drives: 2007 Yaris
I was just reading this which made me assume the fxe had something special in forged rods while the fe did not.
https://en.m.wikipedia.org/wiki/Toyota_NZ_engine
Old 07-11-2015, 01:44 PM   #4
crazylegs
Drives: 2007 Yaris
It also states that the fxe has an aluminum intake manifold which makes me wonder could we use the mate the intake flange from the fxe with the intake manifold from the 1zz engine. That's assuming the intake manifold on the fxe and the fe are the same. And the 1zz intake manifold is aluminum.
Just thinking out loud here
Old 07-29-2015, 09:31 PM   #5
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Fxe has a funky intake manifold tuned for a narrow rpm band.
Old 07-30-2015, 11:03 AM   #6
crazylegs
Drives: 2007 Yaris
Good to know thank you
Old 04-14-2020, 10:37 AM   #7
Is anyone aware as to whether you can just pop a Prius 1.5 in the car while running your stock engine peripherals so that you have a high compression engine?
Old 04-15-2020, 10:52 PM   #8
Neinris
Start looking for a wrecked Prius and test this out!!!
Old 04-17-2020, 09:18 AM   #9
I’ve found a Prius 1nzfxe engine for $100 but it has about 200,000 miles on it. Not sure I want to take the time. The #QCYaris will almost certainly be getting the extra 1nzfe engine I have from TMontague.
Old 04-22-2020, 11:30 AM   #10
Zedicus
Drives: scion xb
the prius C engine is the one to use to make any substantial 'gains'. the original prius 1.5l engine is basically identical internal except for pistons. you can swap pistons to the yaris 1.5l, or swap yaris cams to the original prius engine.
the prius c engine has newer designs on some of the problematic 1nz issues (valve stem seals come to mind) but it requires 'some work' to install.
i have a write up on an install in a 1st gen scion XB, i will post some.
Zedicus is offline   Reply With Quote
forged 1nz turbo build 1nz_tommy Performance Modifications 2 10-22-2014 08:40 AM
1NZ / 2NZ Transmission Compatibility & Aftermarket 2NZ Rods jtw11 Performance Modifications 8 09-03-2013 01:49 PM
Forged Pistons, connecting rods, piston rings etcetc mastaofdisasta Performance Modifications 2 04-18-2010 12:05 PM
GI: 1NZ-FE Forged Rods Nexus1155 Forced Induction Forum 41 03-21-2009 03:29 AM
