Old 07-21-2015, 05:56 PM   #1
shameer_k
Drives: yaris sedan
Engine noise
I am getting this strange noise when starting my car. It mostly happens in the morning or when leaving work in the evening.
Any advice what can be causing this noise? I attached a link with a recording of the noise.
https://soundcloud.com/faraaz-khan-13/engine-noise-2
shameer_k is offline   Reply With Quote
Old 07-21-2015, 07:21 PM   #2
valchrist90731
Drives: 2007 toyota yaris sedan
The noise? That like cricket noise? Might be that serpentine belt check if its old. Hows the condition.
When was the last time it was changed.
The belt that goes on all the pulleys.
valchrist90731 is offline   Reply With Quote
Old 07-21-2015, 07:52 PM   #3
shameer_k
Drives: yaris sedan
it sounds like a scraping/squealing noise.
This was changed about 2 months ago. Same noise before and after.
Old 07-21-2015, 08:56 PM   #4
bail_w
Drives: 2007 Toyota Yaris LB
Year and Mile of the car?
bail_w is offline   Reply With Quote
Old 07-21-2015, 09:31 PM   #5
valchrist90731
Some new belts make noise too.
And I'm serious.
Give it time to break in.
How tight is it?
I don't think it's loose but new parts do need time to break in. Give it a month or two.
Hey it was that cricket sound right? When the car turns over and starts to run right.
I think the noise might be from friction from a new belt.
Don't tighten anything like the incredible hulk.
I'm not saying to retighten just let it relax on it's own. Some new parts need to be broken in on their own.
Who put it in?.
Old 07-22-2015, 09:46 PM   #6
shameer_k
Drives: yaris sedan
It's a 2008 yaris sedan. The mileage is about 140000 km.
It's not the cricket sound.
Old 07-22-2015, 10:41 PM   #7
valchrist90731
Is it constant?
It's more like a very short whistle screeching noise for a quarter of a second after the car finally turns over?
Does the sound go away after this and during driving?
Old 07-23-2015, 10:15 AM   #8
shameer_k
Drives: yaris sedan
Originally Posted by valchrist90731 View Post
Is it constant?
It mostly happens when the car rest for a while, say 5 hrs or more.
Yes, it a short screeching noise. Which goes away far start up.
I do not hear it while driving.
Old 07-23-2015, 01:38 PM   #9
valchrist90731
Who put in the belt?
How's the tension?
Get it adjusted if needed.
Old 07-23-2015, 02:02 PM   #10
shameer_k
Drives: yaris sedan
I got it installed by a local service station. This was done about two months ago. It was carried back last week for tensioning. Noise didn't change.
Old 03-20-2016, 10:26 PM   #11
rene7
Drives: Yaris Sedan Core AT 2010
Did you find the cause of this noise? I'm having the very same problem. Belt's tension looks good to me although, I haven't changed it in a while.
rene7 is offline   Reply With Quote
Old 03-21-2016, 01:07 AM   #12
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Can't believe I didn't find this thread before posting my thread with video here:
http://www.yarisworld.com/forums/showthread.php?t=55661
Mine has been making the same exact noise for a while now. Others have commented on my YouTube about having the same noise. Neither Toyota nor a highly yelp rated local shop were able to diagnose. Best guess was the starter sticking when cold.
Old 03-22-2016, 01:38 PM   #13
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
could it be one of those common toyota VVT start up noises? plenty of examples on the tube.
jack black is offline   Reply With Quote
Old 03-22-2016, 01:50 PM   #14
ern-diz
ern-diz's Avatar
Well, it doesn't happen every time and from the sound of my vid, my mechanic didn't think so.
Old 04-01-2016, 09:58 AM   #15
harda toenail
Drives: Want a yaris
Sounds like the starter solenoid sticking just a bit too long. Common problem in corollas/matrixes/vibes. Sounds very similar. My wife's 10 vibe has had this intermittently since we bought the car.
One thing that may help- only bump the key forward and let the car start itself. Don't hold the key forward until the car starts.
harda toenail is offline   Reply With Quote
Old 04-04-2016, 10:42 AM   #16
ern-diz
ern-diz's Avatar
Thanks; just learned about that recently from the good folks here at YarisWorld. Been starting it that way ever since. Still happens occasionally. If it starts to happen more often, I'm just going to replace the starter.
Toyota's new subcompact will use Mazda's Skyactiv engine Kal-El Off-topic / Other Cars / Everything else Discussions 43 03-25-2014 01:01 AM
Yaris 2007 engine noise / vibrations vincentg DIY / Maintenance / Service 2 06-29-2013 10:03 PM
Speakers make noise when engine is on Lafiro In Car Entertainment + Electronics (audio / video / alarm) 13 01-07-2009 08:52 PM
engine noise?? poshi General Yaris / Vitz Discussion 23 09-04-2006 10:45 PM
