Old 07-22-2015, 01:55 AM   #1
Yaris_Mac
Drives: Gas saver
Top struts... Is this normal?
Is there suppose to be a gap between the body frame and the top struts? This is my second set of lowering springs. I took the Teins S-Tech after using it for 2 weeks and I just finished installing the Tanabe NF210 and noticed the gaps on both sides. I'm not sure if the Tein or even the stock springs had it before. Please note that I have the nut tight all the way with 6mm hex and 17mm box wrench.
Please advise.
Thank you.
Yaris_Mac is offline   Reply With Quote
Old 07-22-2015, 02:20 AM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
normal.
Old 07-22-2015, 02:29 AM   #3
Yaris_Mac
Drives: Gas saver
Thank you!
Old 07-24-2015, 12:42 AM   #4
fourbangingfun
fourbangingfun's Avatar
Normal. Just curious though, why'd you switch from the Tein S to Tanabe?
fourbangingfun is offline   Reply With Quote
Old 07-25-2015, 03:26 AM   #5
Yaris_Mac
Drives: Gas saver
Tein S-Tech:
Rear end was a bit rough on the freeway when going over dips. I feel bad for my 2yr old. Rear was lower than the front even without the bike/bike rack.
Tanabe NF210:
Rear end felt like stock and the drop was perfect except the front had 1/2" gap in the tire/fender and it was very obvious. I didn't like it at all.
S-Tech Front/NF210 Rear:
Rides just like the Tanabe NF210 but with a much better stance. Same gap tire/fender all around.
Found another Yaris.
Old 07-25-2015, 08:10 PM   #6
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
looks good and nice spring combo setup...now are those Miyata rims?
Old 07-26-2015, 12:47 AM   #7
fourbangingfun
I like the combo better actually. Might look into it myself.
Old 07-26-2015, 07:04 PM   #8
Yaris_Mac
Drives: Gas saver
Thank you.
Yes, Miata 14x6 +45 with 20mm spacers front and 26mm spacers rear. I'm on a wrong tire size (185/60) but I got the set for $250 with brand new Potenzas. :)
Old 07-26-2015, 11:47 PM   #9
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
They look good
Sent from my ASUS_Z00AD using Tapatalk
FS: Tein S-Tech Lowering Springs / Tokico Blue Struts & Shocks Freestylin Items for Sale by private party 21 02-04-2014 07:33 PM
Yaris comment on Top Gear USA Season Premiere CTScott General Yaris / Vitz Discussion 18 08-21-2012 11:29 PM
Broken top plates and end links Trish General Yaris / Vitz Discussion 0 04-07-2011 12:28 PM
Top mount or front mount intercooler vitz rs Forced Induction Forum 10 09-14-2010 05:31 AM
Is This Normal? i was told its normal, but i dont think it is jthebeh DIY / Maintenance / Service 3 11-27-2006 08:46 AM
