Old 07-23-2015, 04:22 PM   #1
jlcoki
Drives: Yaris 2007, LB, 3 drs
Yaris 07, 2dr, lb - P/S problem
Hi everyone!
I own a Yaris 07, 2dr, lb and about 5 months ago started with some problems...
This is what happens:
Suddenly when you start the car (1) the P/S light shows in the panel along with the (2) drivers airbag light, (3) the seatbelt beep does not sound and (4) the steering wheel gets hard.
It's resolved by shutting the car off and starting the car again and everything works perfect.
This problem has never came when driving, just when I start the car. The battery is new and I replaced the EPS ECU too. ECU fuses seem to be ok.
I took it for scan and since the problem didn't happen while been there they couldn't get anything. Is like a ghost ha. It just showed old codes apparently from the can communication. May be that's the issue??
I can drive my car anywhere but I can't stand this thing anymore...
If you have any idea of what's generating this I'll appreciate your help!
Here's the video illustrating all this..
Regards...
https://www.dropbox.com/s/2mlqrdswgj...AS%20.MOV?dl=0
jlcoki is offline   Reply With Quote
Old 07-23-2015, 08:37 PM   #2
The CAN bus error could be part of it. Do you leave any devices plugged into the diagnostic connector?
Also, are you running the original alternator or a replacement one?
Old 09-07-2015, 09:30 PM   #3
jlcoki
Hi CT, the alternator is original! Today I found this thread.. It's the only one that sounds similar to whats been happening with my car, but with a different car.. I think the ECU and the PS motor assembly are from the same maker: DENSO
Chevi cobalt thread:
http://m.topix.com/forum/autos/chevr...B7V2DTH5JH/p52
I might buy a PS motor and get it installed and hope this solves the issue.. What you think?
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 09:08 PM
I have problem with the electro ventilator yaris sedan 2005 ramy DIY / Maintenance / Service 3 08-26-2013 09:08 PM
09 Yaris Heater blower problem motoxxx3 DIY / Maintenance / Service 28 10-15-2010 06:45 AM
