Old 08-07-2015, 07:30 PM   #1
Yapyzzer
Drives: 2004 Echo 3rd
AEM FIC install guide for Echo
Okay, so before I go ahead and do this, I figured I might as well check and see if anyone has done this or not, Has anyone made a guide to install the AEM FIC like which wire goes to which wire, which one has to be intercepted vs which one has to be spliced and what not? if not, then I am currently in the process of making a cheat sheet for myself so that I can install it as quick as possible as I need my car within the week.
thanks in advance if you have, if not then in a couple of days I will try and convert mine from paper and pen to pdf.
There is a replacement for your discplacement,Mr.v8 guy.
Yapyzzer is offline   Reply With Quote
Old 09-08-2015, 01:34 PM   #2
I'll update this seeing how I've made some progress programming mine.
I was running 1.07 on the FIC. Things were fine running 0 maps but as soon as I started altering fuel and O2 maps things wouldn't settle once it was in that part of the map.
I just today changed to 1.04 and everything seems to be much happier. I can get my AFR down closer to a safe zone under full power but part throttle seems to be a bit stumble now. I haven't bothered clamping my MAF as I'm not getting any codes other than a Cat efficiency below threshold or my sub O2 sensor voltage is too high.
Sent from my iPod Touch
Ultimate Turbo Pre-Install Guide Focus_Sh1ft Forced Induction Forum 7 09-14-2017 03:28 PM
AEM FIC fight for turbo!!! thatbryanguy Forced Induction Forum 135 08-14-2015 08:22 PM
Question about how to load file to AEM FIC? DKN-YARIS Forced Induction Forum 24 06-01-2013 09:58 PM
FS: Zage Turbo kit, AEM FIC with Pnp Harness djgab101 Items for Sale by private party 32 04-11-2013 10:42 AM
