Old 08-15-2015, 11:26 AM   #1
DC Header install question
Hey guys,
I just finished installing the header. Upon starting it I noticed that light white smoke was coming from the header. I don't think it's a leak as it doesn't smell like eexhaust and it virtually stopped after 2 mins.
Has anyone else noticed this issue, and is there a factory coating that needs to be burned off?
Engine runs fine and no CEL's.
Thanks
Old 08-15-2015, 06:37 PM   #2
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
It's normal. I think it's the new gasket that need to "broken in" after first installation.
Old 08-15-2015, 11:20 PM   #3
Thanks for the info. I started back on the car and installed the lowering springs and turned the car on to take it out for a test drive. No smoke coming from the header, there is obviously a coating of some sort on the header from the factory.
My Yaris is a ton of fun to drive now.
Old 02-09-2017, 10:00 AM   #4
JessMess
Drives: 08 Yaris hatch back
Just curious.. Did you install the header on stock exhaust?? (Everything after header stock?)
JessMess is offline   Reply With Quote
Old 02-09-2017, 10:21 AM   #5
itll be fine
how do you like the power? not going 2zr?
Old 02-09-2017, 10:35 AM   #6
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
itll be fine
I think Jess got you with a zombie thread. This post is 2 yrs old.
On Instagram
On Wheelwell
Old 02-09-2017, 12:13 PM   #7
motherfvcker!
Old 02-09-2017, 09:58 PM   #8
SirDigby
Drives: 2007 yaris 3 door
hahahahahaha!
Question about header outlet size and system diameter Shinare Performance Modifications 10 12-10-2010 09:27 PM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
Received Header & Exhaust..Install Soon AlainMikli Performance Modifications 16 04-25-2009 11:42 PM
n00b suspension install question The Stig DIY / Maintenance / Service 25 07-12-2007 08:58 AM
