Old 05-06-2007, 11:02 AM   #1
ItalianYaris
Drives: 2007 Yaris TS
Send a message via AIM to ItalianYaris Send a message via MSN to ItalianYaris
Question Brake Upgrades for Yaris Hatch!
Hi everyone! Well, we are all into getting more power and stuff from our little Yaris, But as anyone done a nice brake upgrade? Like Brembo kits or something like that?
G.
ItalianYaris is offline   Reply With Quote
Old 05-06-2007, 11:46 AM   #2
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
G.
With the light weight of the YARIS a big set of rotors and 6 piston calipers on the front would probably throw you through the windshield!
blacksan is offline   Reply With Quote
Old 05-06-2007, 11:55 AM   #3
ChinoCharles
Drives: LB
For under $300 you can get cross drilled and/or slotted rotors from Dezod, good pads from Dezod, and some caliper paint from Autozone. Its no Brembo kit, but it'll do the trick.
http://www.dezod.com/cat_brake_rotors5.cfm
http://www.dezod.com/cat_brake_pads10.cfm
http://autozone.com/selectedZip,4423.../selectZip.htm
Old 05-06-2007, 01:03 PM   #4
ItalianYaris
Thanks for the info! Im ot necessarily looking for bigger brakes, just for something better. The thing is the Yaris TS is heavier than the Yaris you guys get in the US. Your model is a 3 door hatch only no? which weights at about 1,010 Kg (2226 pounds), while the Yaris TS (5 Door Hatch) weights at around 1,125 kg. (2480 pounds). I just wanted to know if there was any kit available for the Yaris out there. It comes with 4 disk brakes already, just wanted a better system! Im planning to do some work on it and well, more power, better brakes! :)
Old 05-06-2007, 01:08 PM   #5
blacksan
blacksan's Avatar
Thanks for the info! the thing is the Yaris TS is heavier than the Yaris you guys get in the US. Your model is a 3 door hatch only no? which weights at about 1,010 Kg (2226 pounds), while the Yaris TS (5 Door Hatch) weights at around 1,125 kg. (2480 pounds). I just wanted to know if there was any kit available for the Yaris out there. It comes with 4 disk brakes already, just wanted a better system! Im planning to do some work on it and well, more power, better brakes! :)
I would try different pad material and stainless break lines before buying rotors. The stainless lines add a much firmer feel to the pedal.
Old 05-06-2007, 01:53 PM   #6
drell42
Drives: Blank
I am going to have to agree with you on this one. I was reading PAS mag and they did a hole break jo on the car. At the end they remembered the EBD and said the best bang-for-the-buck and proformance wise, was to just upgrade pads, shoes, and go to s/s lines
drell42 is offline   Reply With Quote
Old 05-06-2007, 02:45 PM   #7
ChinoCharles
Drives: LB
Stainless brake lines just came out too. Search for the thread, I'm lazy.
Old 05-06-2007, 03:19 PM   #8
ItalianYaris
Cool, well let me double check on this! thanks for the info!
Old 05-06-2007, 03:22 PM   #9
blacksan
blacksan's Avatar
I have been using SS brake lines on motorcycles for years and they make a HUGE difference.
Old 05-06-2007, 03:59 PM   #10
ItalianYaris
Do they have a web site?
Old 05-06-2007, 04:01 PM   #11
blacksan
blacksan's Avatar
There are a lot of people that make them. I like Russell brand myself.
http://russellperformance.com/new/
They do not list the YARIS, but I know they can make them.
Old 05-06-2007, 05:14 PM   #12
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
SS brake lines, new pads and better fluid will do the trick. Drilled/slotted rotors won't give you any performance increases.
Old 05-06-2007, 05:17 PM   #13
07typeS
07typeS's Avatar
Drives: 2007 White Toyota Yaris Type S
Send a message via AIM to 07typeS
but they look nice....
TRD Springs w/ KYB Struts and Shocks, Custom CAI w/ K&N filter and pre filter wrap, Weapon R Header, Stock 15 inch alloys, Dezod Performance pads, Tanabe Front Strut Bar, 35% front door Tint and 20% Rear doors back Tint, De-Badged Ass, Custom painted flat black interior, Pioneer deh-p6700bt w/ IPOD hookup, Infinity components up front with custom mounted tweeter, Inifinity 6x9's out back, 1 12" kicker comp cvr........
07typeS is offline   Reply With Quote
Old 05-06-2007, 05:17 PM   #14
blacksan
blacksan's Avatar
The larger rotors do help, but why bother? The car is so dam light that everything but rotors should make a BIG difference, agree?
Old 05-06-2007, 05:23 PM   #15
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
Can you give pictures.
Not sure what a SS is. Did a quick google search and all I see is bunch of wires..
Help a nub..
-- Blen
Old 05-06-2007, 05:26 PM   #16
drell42
Drives: Blank
ss brake lines are, stainless steel braided brake lines. They are still flexable like rubber but under heavy and hot breaking conditions they will not expand like rubber. This gets rid of the "mushy" gummy no brake feel!
Old 05-06-2007, 05:27 PM   #17
blacksan
blacksan's Avatar
Help a nub..
-- Blen
Stainless Steal lines
Old 05-06-2007, 05:32 PM   #18
drell42
Drives: Blank
the only ones that I have seen specificly for the yaris are these ones.....
http://www.hrpworld.com/index.cfm?fo...action=product
DIY INSTALL/REVIEW: Dezod X-Rated Yaris Brake Pads ChinoCharles DIY / Maintenance / Service 40 10-13-2017 05:23 PM
Yaris Hatch Purchase warlock New YARIS Purchase Forum 7 09-02-2007 11:59 PM
Brake upgrades majorposer Wheels, Tires and Suspension Forum sponsored by The Tire Rack 27 06-06-2007 03:43 AM
big brake kit turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-13-2007 01:44 PM
I finally test drove a Yaris Hatch... ECHOKnight2000 New YARIS Purchase Forum 10 02-01-2007 12:18 PM
