Old 08-16-2015, 06:35 PM   #1
sportivoecho
Drives: toyota echo sportivo
turbo 1nzfe mapping issues
i have a 2005 toyota echo sportivo (australia) which ive turbod using the zage turbo kit, im having a few issues with the mapping. ive had it tuned professionally at a reputable tune shop here in australia but the car cannot get away from a flat spot between 1500-2000rpm right before it builds boost. if we reduce the fuel in that area it gets worse, if we increase it it gets better but we can only increase it so much until the fuel economy goes out the door.
its very strange, its only in that one spot that it has a huge flat spot. i was wondering if anyone has had this issue or could lead me in the right direction?
thanks
sportivoecho is offline   Reply With Quote
Old 08-16-2015, 07:24 PM   #2
What are you tuning with?
Do you have an AFR gauge installed?
Old 08-18-2015, 11:54 AM   #3
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Draw thru or blow thru MAF?
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-18-2015, 08:06 PM   #4
sportivoecho
im tuning with an EMS stinger v4. never had issues with these ecu's. and no i dont have a afr gauge but i go for a drive with the tuner and it is lack of fuel, we remove fuel it gets worse, we add fuel it gets better but its still there and it reaches a point were adding more fuel will be ridiculous because obviously there is another issue.
the flat spot is so frustrating!
its a draw thru MAF.
Mapping for turbo install djhuddy2442 Forced Induction Forum 0 09-17-2014 10:18 AM
Just wanted to share this: turbo 1NZFE as400g33k Performance Modifications 34 04-26-2013 10:39 AM
1nzfe + glanza turbo kit alfog Forced Induction Forum 7 03-08-2013 09:04 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
