Old 08-17-2015, 05:19 PM   #1
Kitt
Kitt's Avatar
Fram oil filters
Hi folks...
I've used these filters for years now and I have no issues so far, however, i've been told that those are the worst filters ever, but want to make sure I am not doing a long term damage to the engine by using it.
Old 08-17-2015, 05:26 PM   #2
ricardocanedo621
ricardocanedo621's Avatar
Drives: 2008 Yaris Base
I think it depends on the oil change intervals. 3,000 to 5,000 mile intervals should be okay. But there are better alternatives like Denso or Purolator. I use the DENSO 150-1000 oil filter and it is the same as OEM Toyota but has better filtration media, silicone anti drain back valve and more durable housing.
ricardocanedo621 is offline   Reply With Quote
Old 08-17-2015, 05:36 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Personally I would never use a Fram filter. You can Google and find al sorts of information on them. The only filters I have used for 5 years are from Amsoil or Mann and they have been great. Denso as well is a solid choice as it is the OEM filter.
Sent from my SCH-I545 using Tapatalk
Old 08-17-2015, 05:41 PM   #4
ricardocanedo621
Denso First Time Fit
Toyota OEM
Fram
Old 08-17-2015, 07:00 PM   #5
shepd
Drives: 2007 Yaris 5 door RS
Some have found defective Fram filters (eg: The media isn't stuck together right out of the box), but we'll ignore those as they are the minority. What is normal with the cheap Frams (not the higher end ones) is that the filter ends are made of cardboard. This seems like (to most people) a bad idea since cardboard likes to dissolve in liquid. Other companies typically crimp with steel. Also the drainback valve design on Fram filters can be poor. These issues can, in some unusual circumstances, lead to the filter collapsing.
That being said, there's many who have used their filters without issues for decades. I only use Fram filters when they are significantly cheaper, because they are built like a cheap discount filter, they should be sold at that price. However, sometimes Fram filters are sold at "normal" prices, in which case, why buy not just buy something made better for the exact same price?
Only in one circumstance would I flat out refuse to use a Fram filter: If I were trying to minimize the number of oil changes I have to do. If I were using synthetic oil to try to get those crazy 10,000+ mile oil changes some people do, I think a discount filter is a very bad idea!
shepd is offline   Reply With Quote
Old 08-17-2015, 07:24 PM   #6
I've never had issues with fram filters, but they have ends made of cardboard, this is an issue when comes reliability.
Sent from my A0001 using Tapatalk
Old 08-17-2015, 09:17 PM   #7
Rigaud
Drives: 2009 Yaris
Fram = cheap!!! It's a hit and miss!!!
No thanks for me.
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 08-18-2015, 02:07 AM   #8
bairjo
Mobile1....blows them all away in capicity and quality. As for fram, you may as well put a roll of toilet paper in a a coffee can with an adapter to the oil filter threads.....
Old 08-18-2015, 04:32 AM   #9
LTHatch
Drives: 2013 Yaris Hatchback L
Used Fram on my last oil change, not a fan after hearing an odd taping on warm idle(after about 1500miles). Back to the OEM filter, noise is gone. Used Mobil 1 before, that filter was absolutely bad ass, 5K miles and the oil was clear just like when i first put it in.
If your wallet allows, try out Mobil 1 and go for 7k+ intervals with full synthetic.
LTHatch is offline   Reply With Quote
Old 08-18-2015, 06:18 AM   #10
bronsin
bronsin's Avatar
FRAM filters look crudely made to the general public, but they are tested in a lab to work. If they resulted in engines that wore out prematurely by this time they would be out of business.
Strangely they cost more than Purolator filters!
As long as you aren't going 10,000 miles between oil changes I think youll be fine.
Old 08-18-2015, 07:25 AM   #11
Rigaud
Drives: 2009 Yaris
Yes however their the least effective filter to use. Don't know about you but I don't use cheap filters.
Old 08-18-2015, 08:00 AM   #12
nortonfb
Drives: 2007
I've been using Denso (or Mann). Never saw the first time kit.
There is a number ( Denso 150-1006?) which is for the Yaris.
Since all the filters must meet SAE specs, I would be surprised to see a problem,
as long as they are used as intended.
I would opt for a better filter if I was running the car hard. Also I have the magnetic
drain plug.
nortonfb is offline   Reply With Quote
Old 08-18-2015, 10:35 AM   #13
bronsin
bronsin's Avatar
My 1974 VW Beetle had NO oil filter (and 2.5 quarts of oil) and the crank, rods, and camshaft and their bearings went 250,000 miles and still weren't worn out.
And that's an aircooled engine.
Cheap oil filters for me!
Old 08-18-2015, 12:35 PM   #14
bail_w
Drives: 2007 Toyota Yaris LB
I use PureOne oil filters because I change engine oil every 5k miles. It is cheaper than mobile1 and the construction materials are on par with mobile1 (Metal end caps , silicon ADBV etc).
bail_w is offline   Reply With Quote
Old 08-18-2015, 04:07 PM   #15
ricardocanedo621
drain plug.
Denso First Time Fit is just a branding its the same as the one you mentioned. Denso 150-1000 is the one for our cars.
Old 08-18-2015, 04:13 PM   #16
ricardocanedo621
Isn't that a boxer engine? So a very different design than our cars with variable valve timing and such that can be damaged from particulates in the oil hence the reason for the oil filter.
Old 08-18-2015, 10:51 PM   #17
Kitt
Kitt's Avatar
Thanks for the feedback folks, I'll return to denso/oem filters and keep you posted.
Old 08-19-2015, 06:16 AM   #18
bronsin
bronsin's Avatar
Yes its a boxer engine.
I would argue the fact that ALL the bearings were still in spec after 250k miles and NO oil filter means the modern features of our Yaris's engine wont be damaged either. And lets remember the FRAM filters are laboratory tested to a standard for modern cars. They meet the same standards as every other filter in their class for effectiveness and durability, no matter their dubious looking construction.
The notion that FRAM filters aren't up to snuff is a conclusion of non engineers with no lab to test oil filters and no experience in that field.
And then theres this. After around twelve years and ~125k miles the engine may be doing just fine but the rest of the car is a decade out of style and modern safety and convenience features.
For a lot of people that means new car time...
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
