#1 |
![]() ![]() Drives: Yaris 2008 HB Join Date: Sep 2007
Mega Voltage stabilizer??
Is this anything?
http://www.performancechiptuning.com...LCD+Module/13/ Mega Voltage stabilizer in combination with supplementary earth bring you electrical efficiency. Mega Raizin brings you not only ideal electrical efficiency and voltage supply stabilization, but with our original circuitry design and our special noise reduction condenser you can enjoy diminished noise and lessened high-frequency impedance. Save Up To 5% On Fuel! Increase Horsepower Up To 7% more hp! |
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
it suppose to balance out the volt..similar to ground wire..i have them, but you dont gain hp or anything like that(i dont feel anything)..when you turn on the car it will read out your battery volt..
so basically i think this is just a cosmetic for engine....
#3 |
feed my pet
imo voltage stabilizers is only needed if you have high electrical load mainly the audio enthusiasts e.g. like having an amp, crossover, bass box etc.
I'm using this instead: http://fuelbankevo.com/fuelbank_e/effect/index.html |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| Ohm's Law and Setting Amp Gain | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 24 | 03-13-2012 09:34 PM |
| Voltage Stabilizer | walt101786 | Performance Modifications | 3 | 08-12-2010 05:46 PM |
| JDM GROUND WIRE VOLTAGE STABILIZER TOYOTA YARIS | jamal1984 | Performance Modifications | 17 | 03-26-2007 01:01 PM |
