Old 08-23-2015, 06:32 PM   #1
mario98c
mario98c's Avatar
Clutch fork movement
Anyone know how much the clutch fork should move normally when the clutch pedal is depressed? I'm trying to know if the fork is moving the pressure plate all the way down because my Yaris wont go into gear if the engine is on. I already bleed the clutch slave. I think that I accidentally bend the clutch disc when trying to remove or install the transmission by leaving it rest on the clutch when I was tired trying to get the trans to align with the engine but I want to be completely sure before removing the trans again. :/
Old 08-23-2015, 11:49 PM   #2
Make sure your freeplay is adjusted correctly inside the car
Getting Rid of the infamous Clutch "Shudder" tmontague DIY / Maintenance / Service 14 07-08-2023 01:56 PM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
need help on my 2008 yaris compress clutch susucosp DIY / Maintenance / Service 0 05-15-2014 03:48 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
