Old 08-24-2015, 12:19 AM   #1
xdarkxfirex
Drives: 2015 yaris le
Suspension sounds? Sway Bar Bushings?
For the past while, I notice creaking sounds going over bumps. I checked control arms, bushings, tie rod, shocks etc, didnt notice anything. The only possible thing left would be the sway bar bushings. How do you get those off? They are really inaccessible? I was trying to grease the insides and couldnt even get a bolt loose. I used a light impact, and a breaker bar on the bottom and nothing. I soaked it with atf, and it still doesnt open. I greased the sides with lithium grease, still not much has changed.
Any advice?
xdarkxfirex is offline   Reply With Quote
Old 08-24-2015, 07:38 AM   #2
ex-x-fire
Get someone to rock the car side to side (by pushing on the roof) while you reach under the car to feel for the creaky noise.
Old 08-24-2015, 09:07 AM   #3
I'm hoping i'm wrong but I think the only way to access the bushings is by dropping the sub frame. I don't see a way to access all 4 bolts by leaving the sub frame installed.
How many km's on your car? Check the strut mount and bearings.
bushing, control arm, suspension, sway bar, yaris
Which Rear Sway Bar?? Airswoosh1 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-23-2013 03:49 AM
TRD rear sway bar brackets and bushings MasterShake Wheels, Tires and Suspension Forum sponsored by The Tire Rack 23 10-22-2012 09:26 PM
My Ultra Racing rear sway bar install CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 49 03-03-2011 02:08 AM
sway bar... Toyota dealers must be insane! RedRide General Yaris / Vitz Discussion 10 07-24-2009 03:39 AM
Sway bar and struts DOMAV Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-17-2009 02:26 AM
