Old 09-08-2015, 02:01 PM   #1
habdala
Drives: 207 Yaris Hthb
Codes 51, 53 and 73
Hi there! newbie here.
I have an 07 Yaris that was in an fender bender and the driver side bag was deployed, when I got the car there where no lights the SRS light was off. I bought a used airbag ECU and Spiral cable and after a week of use the SRS light came on. I was able to read the codes by shorting 4 and 13 pin and I got these codes:
51, 53 and 73
Any help will be appreciated.
Thank you!
habdala is offline   Reply With Quote
Old 09-08-2015, 07:10 PM   #2
51: Short or open in driver side squib circuit
53: Short or open in driver side squib second step circuit
73: Short or open in driver side front pretensioner squib
The first and second indicate that you either got a bad clockspring or airbag (or did not plug in the connectors).
The third is because the seat belt needs to be replaced. There is a charge in the seatbelt coil that locks the seatbelt when the airbag deploys.
Old 09-09-2015, 12:14 AM   #3
habdala
Thnx!
