Old 09-12-2015, 11:28 AM   #1
s3la
s3la's Avatar
Drives: 2013 Toyota Yaris SE
Question Removing Front Passenger Seat in 2013 Yaris
I need to temporarily remove the front passenger seat in my 2013 Yaris. What is the best procedure to follow so as not to damage or trip the SRS system installed on the underside of the seat? I assume I need to disconnect the battery before messing with the wires but is there anything else I should do?
Any help or suggestions are greatly appreciated.
s3la is offline   Reply With Quote
Old 09-12-2015, 01:18 PM   #2
As long as you do it without turning the ignition on, there will not be an issue. Unplugging the battery is not a bad idea for safety's sake with the seat mounted airbags, but the SRS system is not powered unless the ignition is on.
If you intend to drive the car with the passenger seat out, you will trigger about 10 error codes for the SRS, which you will then have to manually clear, after reinstalling the seat.
2015 Yaris seat in a 2009 yaris or other seat options? Shinare DIY / Maintenance / Service 1 11-10-2014 07:32 PM
So how are you liking your 2012 & 2013 Yaris SE? The Squirrel Mafia Third Gen Yaris General Discussion 32 04-14-2014 02:30 PM
[REQUEST] Removing Front Bumper + Faulty Electric Window '04 Yaris lufcfan DIY / Maintenance / Service 0 03-03-2010 06:29 PM
