Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > UK
Old 09-15-2015, 03:55 PM   #1
ben 10
Drives: yaris 1litre 2002
is ecu blown
hello newby here
wifes car battery put in wrong way around blew main 50 amp fuse by battery all other fuses ok inside car is ECU blown
have replaced blown fuse
H E L P
thank in advance
ben 10 is offline   Reply With Quote
Old 09-15-2015, 04:11 PM   #2
Are you saying the car currently does not run, or does run but you simply questioning if you may have caused ECU damage?
Old 09-15-2015, 04:24 PM   #3
ben 10
wee yari
car turns over fine but will not start checked every fuse i could find took off one of the feeds to the plug spark box and checked for power while swinging over no power there so im suspecting damage to ecu
ben
Old 09-15-2015, 05:00 PM   #4
Try another key if you have the immobilizer.
Old 09-17-2015, 08:14 AM   #5
ben 10
tried other key same thing
is there another fuse hideing somewhere?
ben
Old 09-17-2015, 10:01 PM   #6
ben
Did you check the fuse panel under the dashboard, inside the car?
Also, check AM2, as it directly powers the coils.
Need Help with 2NZ ECU pinout Aleil DIY / Maintenance / Service 3 12-28-2020 09:40 AM
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 01:50 AM
standalone and stock ecu Radou Performance Modifications 0 06-16-2013 04:47 PM
Yaris ECU broken??!!!!!! phb10186 General Yaris / Vitz Discussion 30 05-26-2010 09:56 AM
Tricking the ECU to Relearn AF map gwasabi Performance Modifications 126 05-16-2009 06:15 PM
