#1 |
![]() Drives: 08 yaris sedan Join Date: Sep 2015
Engine/Transmission mount... How?
How to replace the engine tranny mount on 08 Yaris auto sedan. I did the top pass side mount and rear tourque mount. Just got the one left...
Where is it located and about how long to swap out I'm good w cars I just like to ask and know ahead of time. Thanks in advance Keith |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
Remove the intake and battery and it's right below.
#3 |
Awesome thanks for responding
#4 |
Any tips or tricks for this mount job? I'm gonna tackle it tomorrow when my wife gets home from work.
Thanks in advance! |
#5 |
![]() ![]() ![]() Drives: Vitz RS Join Date: Feb 2009
To do this you don't need to raise the car I did this with my Vitz RS parked in my driveway.
Remove the intake air box - Philip screw driver and 10mm socket with and extension. Remove battery and battery tray - 10mm and 12mm Support the tranny - Toyota scissors jack should do just fine. Remove the mount - about 5 14mm bolts and the 19mm bolt and nut that goes thru the mount. It is not a difficult task. I rate it's difficulty similar to changing the out two mounts. Approximate time is about 1hr from start to finish and less if you have done it before. |
#6 |
Doesn't sound bad. The hard one was the rear for me. This sounds pretty straight forward!
Thanks for replying!!! |
#7 |
Should I do this mount as well after I do the driver side one and is it hard to do? The other two were not that bad..
#8 |
All done! Car doesn't make any viberation noise or clunks into gear after doing 3 mounts. Thanks for the help! Very much appericated! Really I mean that, very helpful people here. God bless -Keith |
| Polyurethane Engine Mount (not 3m) | KTS | Performance Modifications | 0 | 08-24-2015 05:45 PM |
| Top mount or front mount intercooler | vitz rs | Forced Induction Forum | 10 | 09-14-2010 05:31 AM |
| DIY Cellphone Car mount | Arkhangel | DIY / Maintenance / Service | 3 | 08-24-2010 03:37 PM |
| Anyone using ProClip Angled Mount for iPhone? | AliCLick | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 01-21-2010 07:07 PM |
| DIY Camera Mount -- No Cost Version | KCALB SIRAY | DIY / Maintenance / Service | 20 | 06-08-2009 03:12 PM |
