Old 09-20-2015, 08:29 PM   #1
attrapereves
Drives: 2010 Yaris 2dr 5spd
Dipstick
Does anyone else find the Yaris oil dipstick hard to read? I changed my oil yesterday and find it near impossible to tell where the actual oil level is. I see light marks of oil going up and inch or two past the high point. I only put 3.5qt of oil in, so there is no way I put too much in.
attrapereves is offline   Reply With Quote
Old 09-20-2015, 08:55 PM   #2
this is a well known "problem" with the yaris. I'd recommend you buy a valve controlled funnel with measurements on the side and fill your oil filter and then engine with that to the specified amount.
Proper amount is:
3.7L w/ the filter
3.4L w/ out filter
run the engine for a few hundred km's and then check it after it's been sitting for a few mins on level ground. It should then be more legible and should roughly be to the top of the hatched lines. You'll never get a straight crisp line on the dipstick with the 1nz engine
Old 09-21-2015, 01:22 AM   #3
bairjo
my dipstick doesn't get checked like it used to...pretty much dry on both sides.
Oh wait...never mind...I misunderstood the thread and thought it was about something else.
Old 09-21-2015, 02:32 AM   #4
nookandcrannycar
Old 09-21-2015, 11:31 PM   #5
shepd
Drives: 2007 Yaris 5 door RS
On cars with hard to read dipsticks (or just poor lighting in the area) I like to lay a paper towel on the end of the dipstick and check where the oil stain goes to. :)
shepd is offline   Reply With Quote
Old 09-22-2015, 01:12 PM   #6
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
Not sure how much the dip stick has changed over the Yaris years, but on mine I have to flip it over after taking it out, and read the designated area where the bends are on the dipstick - which I assume are there to keep oil on stick, as not to scrape/smear off while removing it (like it does on the other side of stick).
Kalispel is offline   Reply With Quote
Missing Oil Dipstick wooverstone8 General Yaris / Vitz Discussion 14 06-16-2012 08:52 AM
OEM Dipstick "smells" inthebuff DIY / Maintenance / Service 2 05-07-2011 11:50 AM
Dipstick covered in oil-help! DaveG DIY / Maintenance / Service 34 05-05-2011 06:42 PM
2007 OEM dipstick l3igApple DIY / Maintenance / Service 5 04-19-2010 11:25 PM
Aftermarket engine dipstick sroberts General Yaris / Vitz Discussion 1 08-10-2006 09:44 PM
