Old 09-22-2015, 08:57 AM   #1
Psychochops
Drives: 2008 toyota yaris sedan
Alternator change issues
I changed out the battery(battery light was on and the battery was over 2 years old) on Sunday and alternator the next day(battery light was still on before changing alternator) on my 2008 toyota yaris and when I started it up, the battery indicator was gone but now the P/S (power steering) light is on. I have no power steering, no tail lights, no brake lights, no turn signals, wipers don't work, radio doesn't work, speedometer doesn't work. Head lights still work. Hazard lights work in front, but not the back. Horn still works. Anyone have any suggestions? I've read on many forums to have the alternator checked.
Psychochops is offline   Reply With Quote
Old 09-22-2015, 08:38 PM   #2
Check the large fusible links on the positive battery terminal. If you changed the alternator with the battery connected you most likely popped one of the links.
Old 09-24-2015, 08:32 AM   #3
Psychochops
Thank you sir. That's exactly what happened. I checked the fusible link but it looked like the fuses were still intact. After removing it and upon better inspection I saw that it did indeed pop. Thanks again.
Toyota Recalls auxmike General Yaris / Vitz Discussion 535 02-25-2021 06:13 PM
Steering Wheel Jams, Battery Warning Light flickers, Starting Issues tmrtza In Car Entertainment + Electronics (audio / video / alarm) 3 10-31-2014 09:01 PM
Auto insurance issues from modifying a Yaris? RMcG General Yaris / Vitz Discussion 11 06-24-2012 04:38 PM
CV joints or axel issues aucorium DIY / Maintenance / Service 1 02-17-2010 09:10 PM
Exhaust clearance issues... YaYa1320 Performance Modifications 12 10-07-2009 04:46 PM
