Old 09-22-2015, 02:31 PM   #1
xdarkxfirex
Drives: 2015 yaris le
How to access parking brake cable near front?
I want to lubricate it but I cant figure out how to access it? Anyone have a part diagram, or steps on how to access it?
xdarkxfirex is offline   Reply With Quote
Old 09-22-2015, 03:58 PM   #2
what part are you looking to lubricate? to access the part that connects to the lever in the car just remove the middle console.
To access it under the car then just jack up the car, get underneath it and follow the cables as they snake from each wheel to the middle of the car and then up. The heat shield is likely in the way, depending on what you need to do
cable, parking brake, sound, squeak
Problem removing front brake rotor jkuchta DIY / Maintenance / Service 24 02-27-2016 10:41 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 05:43 PM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 09:14 PM
Parking Brake Adjustment Q's Lafiro DIY / Maintenance / Service 3 04-13-2009 09:19 PM
Parking Brake Geelmeel General Yaris / Vitz Discussion 3 06-07-2007 12:06 PM
