Old 09-24-2015, 10:57 PM   #1
Perrin.DM
Drives: 2006 Toyota Yaris
Question Problem with DRL's and headlight's/parking lights
Vehicle - 2006 Yaris
Symptoms are as follows;
Start car, disengage parking break - DRL's do not come on.
Turn headlight switch to park light position - lights do not come on but headlight indicator on panel illuminates.
Turn switch further for headlights - the driver headlight comes on very dimly and front driver side park light turns on; no other lights come on.
Push lever forward for high beams - high beams and all parking lights turn on as per normal. This is how I have been driving for the past couple days.
I disconnected the DRL relay box and I still have the same symptoms as above.
Fuses seem to be fine although I may not have checked them all as they are labelled with limited descriptive acronyms.
Perrin.DM is offline   Reply With Quote
Old 09-24-2015, 11:35 PM   #2
Perrin.DM
This issue has been resolved.
Both headlights went at the same time and caused all these symptoms. I've only had them go one at a time so I haven't seen what happens when both go at once. The symptoms through me off when trying to troubleshoot the issue.
A first for me.
Old 09-25-2015, 03:41 AM   #3
bairjo
Welcome to the forum.... You came to the right place for problem solving help about the Yaris. At the same time we welcome you contributions in solving problems as well....you did good on both fronts.
drl, headlight, parking light
park lights not working koppe In Car Entertainment + Electronics (audio / video / alarm) 13 06-06-2025 02:24 AM
DC Sports CAI interference problem with fog lights beaker Performance Modifications 5 09-15-2014 07:26 PM
Problem with lights. Grantstead DIY / Maintenance / Service 9 07-11-2011 02:14 PM
BIG driving lights.... how? jonismyname Cosmetic Modifications (Exterior/Interior) 22 09-30-2010 07:54 AM
