Old 09-30-2015, 07:25 AM   #1
hondajt
hondajt's Avatar
Drives: 2013 Yaris LE 5Dr
09 with yellow/foggy headlights
My wife's 09 Yaris 5dr is always parked outside and we don't wash/wax like we should and the headlamps are getting less effective. I've just replaced the bulbs with new ones, hoping it was that, but it's definitely the yellow/foggyness on the headlamps.
I've polished my headlamps before on other cars, and no matter what I did, about a year later it always came back, even when regularly applying protectant.
I'm thinking of ordering the LED foglights I've seen here, hoping they would compensate, but I might instead just buy new headlamps from online or something.
What have you done? Any advice for someone without a lot of time free?
Looking for fun!
hondajt is offline   Reply With Quote
Old 09-30-2015, 10:05 AM   #2
Seen it?
http://www.yarisworld.com/forums/showthread.php?t=53750
I think, short of sanding down and applying a fresh coat of clear, shelf products will give you a year max before needing to go at them again.
Old 09-30-2015, 07:29 PM   #3
jcboy
Drives: Sedan 07
^this. minus applying a coat of clear.
Sand them down with 800 Grit, then 1000, then 2500 or 4000 (don't go lower than 2500 for the last sand down)
hand polish using a hand-type rubbing compound. (safer than buffing machine + machine rubbing compound IMO). VOILA!
it should last you a good 2 years at the least. don't use any sort of protectant.
if it doesnt, it means that youre headlights are exposed to good amount of UV rays--be it the sun or from the HID bulbs.
Old 10-06-2015, 09:55 PM   #4
24boosted
Drives: 09 yrs
I just wet sand with 2,000 grit and buff it out with an orbital polisher using Mothers compound and finisher. Comes out clear as glass.
24boosted is offline   Reply With Quote
Sedan HID Projector Retrofit Headlights !yaris! Cosmetic Modifications (Exterior/Interior) 10 10-26-2017 02:31 AM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
2010 yaris Projector headlights yaris2010RS Items for Sale by private party 9 01-09-2012 05:31 PM
Best Aftermarket Headlights MadMax Cosmetic Modifications (Exterior/Interior) 3 06-04-2009 06:50 PM
