#1 |
![]() ![]() Drives: 2012 Yaris 5dr Hatch Join Date: Oct 2014
Stock cat delete cel?
Does anyone know if those 02 sensor spacers work to eliminate a cel if I delete the cat?
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
a secondary o2 simulator sends a signal to the ecu about once every second at the correct voltage for a clean catalyst. a spacer just moves the o2 sensor away from the path. I don't know why you'd do this. if you remove catalyst an incorrect signal will be sent to the ecu tripping a cel. you should not remove your catalyst unless you are using car for racing only. you will only gain about 1-2 hp, but can incur a $10,000 epa fine if it is discovered it has been removed. FEDERAL LAW (idk about PR)
#3 | |
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
http://www.magnumtuning.com/en/detai...r/toyota/yaris A spacer could work, but there's really no guarantee.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
| more performace/MPG with cat delete? | Shinare | Performance Modifications | 3 | 06-22-2013 08:20 PM |
| Secondary Cat Delete? | ApolloJA | Performance Modifications | 4 | 04-28-2013 11:42 AM |
| Cat lovers, Cat haters, this is a MUST READ | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 0 | 10-14-2012 06:20 AM |
| FS/ 2007-2009 YARIS 3 DOOR STOCK PARTS | ROCKLAND TOYOTA | Items for Sale by private party | 5 | 06-26-2012 07:50 PM |
| lots of stock parts 2007 yaris h/b and some after market parts | laszlo | Items for Sale by private party | 19 | 05-17-2009 04:19 PM |
