Old 10-06-2015, 03:32 PM   #1
nordica
Drives: None yet
High biting point normal?
Hi all,
have a question that may or may not be hard to answer. I'm looking to buy my first can and a used Yaris seems to be an affordable and reliable choice. I tested one yesterday, from 2003, 1.0l, that was in great condition although it has 90k miles on it (if I did the conversion right). The one thing I reacted on was that the biting point of the clutch was pretty high; I only noticed when starting in first gear, wasn't prepared for having to let the clutch up so far. My dad had the same experience (stalled once). We're no newbies to stick shifts, it should be said, especially him. I know it can be a sign of a worn down clutch if it goes higher, but also that cars are different. So- does anyone know if it is typical for the Yaris (03) to have a rather high clutch biting point?
thankful for any advice!
nordica is offline   Reply With Quote
Old 10-06-2015, 10:09 PM   #2
CoryM
Drives: 2009 5-door, 5-speed
There are very few 1.0Ls here. The 1.5L definitely has a high pedal though so it may be normal. The 1.5l clutch is also very long-lived; people get well over 200,000km out of them regularly. Can't be of much more help without seeing the car.
Cheers.
Old 10-07-2015, 08:56 PM   #3
BLKHILLSGUY
Drives: 2011 3dr LB Polar White
My 11 Yaris 1.5 had that kinda clutch. I OFTEN killed it in 1st gear and I have driven manual my whole life. The 15 Yaris has a new, much improved clutch.
BLKHILLSGUY is offline   Reply With Quote
High Beam Mod stran DIY / Maintenance / Service 1 11-13-2008 11:06 AM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
Why do all low profile tires have to be of high performance design? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-16-2007 01:23 AM
RPMs high when cold, not switching gears donairs DIY / Maintenance / Service 11 12-12-2006 02:43 PM
